Bronco Suspension and wheels and tires
hollandermotorsports
As many know I stripped these parts off of the Bronco I am parting out. Long story short I'm building a stock width TTB truck now so that's why I got the parts. But I ended up buying a complete other kit as well. So here is my list of extra parts. Make me an offer and we can go from there. Solo cut and turned beams with uniball inner pivots, solo coil over and bypass hoops, 12" x 2.5" coil overs, solo hiemed radius arms with brackets, stock ford Bronco 9", VSS kit, 4 fairly new 35" GT grabbers on Methods and 1 brand new set up. I plan to sell the beams loaded knuckle to knuckle with 4.88 gears in them so you can slam and go. Make offer on parts you need. 760-803-9469
Re: Bronco Suspension and wheels and tires
how much for the wheels/tires?
Really only interested in the wheels...but understand if you don't want to seperate
- hooter95
- Bronco Info: 95, 5.0 and M5OD, Solo Motorsports cut and turned beams with heimed radius arms, Deaver j40 springs
How much for solo engine cage?
If you end up splitting up front end parts I'll take the 4.88 3rd
If diff comes out I will keep for my Bronco same gears sorry.cs_drums wrote:If you end up splitting up front end parts I'll take the 4.88 3rd
$500hooter95 wrote:How much for solo engine cage?
I would really like $1300 for the complete set or just keep for the new truck.robertcrav wrote:how much for the wheels/tires?
- Randyg12
- Bronco Info: I have a ford ranger, looking to upgrade to a bronco
What size are the wheels? Interested in the whole tire package.
15"Randyg12 wrote:What size are the wheels? Interested in the whole tire package.
eoffroader
How much for the radius arms?
I'm not really looking to separate from the beams.eoffroader wrote:How much for the radius arms?
Update I am planning on keeping the shocks, wheels, 9", and front diff. So I will do $2k for hoops, beams, radius arms with brackets and hardware.
Any chance it's got nice gray 92-96 door panels?
No sorryVintageIronFab wrote:Any chance it's got nice gray 92-96 door panels?
eoffroader
Ok thanks anyways that is a good deal for sure though
