Dana 44 IFS Third Member - 4:56, Open
Cleaned up with new axle seals. The gears have the common section of rust from not using 4wd. Does not affect performance. They have about 3k or less running miles on them. The slip yoke has been ported just enough to handle 16" of travel with cut and turned beams. Located in Yucaipa 92399, about 20 minutes west of LeDuc's. $380
Re: Dana 44 IFS Third Member - 4:56, Open
Arg I wish it was 4.88 GLWS
Sale pending.
Sold and gone. Thanks a bunch Fufimi.
- FUFIMI
Not going to be using it anytime soon, so back up for sale. Also have a set of bare beams and a ttb crossmember if you have a non ttb rig and want to run beams. Let me know if interested. Number is 951-956-6922
- FUFIMI
Now this is the right thread, I had both tabs opened and replied on the wrong one haha
Still wish it was 4.88 glws
highroad
- Bronco Info: 01' Ford Sport Trac/LT/347/37's/4x4
Are these high or low pinion? I'm looking for a third member option to swap into an IFS Sport trac with A-arms......wondering if this might fit better than the Ford 8.8 ifs.
They are high pinion.
highroad
Thanks, just found a picture. Sorry to clutter your FS thread, but the 4.56 gearing is what I would need, just not sure if the high pinion will clear the a-arm mount. GLWScs_drums wrote:They are high pinion.
- FUFIMI
It's all good and thanks
- rdcjuanb
Damn, I need this bad..
- FUFIMI
Sale pending on the third member. Still have beams and bronco crossmember
- FUFIMI
Third and crossmember still available
interested in shipping to DE
- rdcjuanb
Ever come towards OC?
- FUFIMI
Not really, sale is pending right now though. If it does not happen you are next in line
- keenanduran1
Thank you!!
