Bronco / F150 Ford Twin Traction Beam 4"-6" front end lift parts
I bought this kit new and installed it on my '93 Bronco about 7 years ago. The kit has about 9000 street miles on it plus about 200 miles of light trail use (fireroads). It spent this entire time garage kept in California so it is in solid shape. The finish is flaking on the brackets and radius arms thus it has a small amount of light surface rust in a few places. Everything is solid and straight. The brackets are very strong and include backing plates where necessary.The brackets will allow 4" or 6" of front end lift and come with the mounting hardware. I kept the 4" springs on my Bronco so if you want to go 4", you will need new 4" lift coil springs (the ones included are for a 6" lift). If you want to lift your truck 6", you will need new shocks (the ones included are for a 4" lift). You will also need to buy a drop pitman arm use this lift. The included 4" lift shocks came with the kit and are not great but they work. The front of the tire (auxiliary shocks) are worn out and cycle ruff. You will also most likely need new alignment cams once the lift is installed. For the 4" lift, my stock brake lines worked fine, if you go 6" you might need new extended front brake lines.I will include the used poly radius arm bushings and original instructions. This kit requires drilling into your front crossmember (for drop brackets) and frame (for extended radius arms).
Asking $400 for everything or $300 for everything without the springs
Pick up in north Orange County CA
Josh
Dick Cepek 4"-6" front drop brackets & Extened Radius Arms
jab-man
- Bronco Info: 1993 5.0 in OJ White / Solo C&T & heimed arms / 4.56 front and rear with 33's
PrerunninBronco90
- Bronco Info: 1990 Bronco Custom 300 Cu 4.9L I6 M5R2 5 spd
Re: Dick Cepek 4"-6" front drop brackets & Extened Radius Arms
Would you sell the radius arms and the drop brackets only? if so for how much?
jab-man
Sure, i'll sell the radius arms and drop brackets for $250.
Kenny's 94
- Bronco Info: 94 Bronco XLT, 2 1/2" RC lift, American AR-23 wheels, 33" BFG KO's.
Could you give me a price on shipping to Virginia Beach Virginia 23464
Thanks Kenny
Thanks Kenny
jab-man
Sorry, due to weight and awkward size, this is local pickup only
I MIGHT BE INTERESTED IN IT IF NO BUYER IN LOCATED IN LOS ANGELES
jab-man
Sounds good, let me know if you want to see it.
josh
josh
WhiplashSmile
- Bronco Info: 89 Bronco - in progress
Josh if you know anyone that gets up to the bay area and the arms/brackets are still around i will buy them.
Sam
408-628-2716
Sam
408-628-2716
