bronco f150 shackle hangers and shackles
Kel Fab Creations
Bronco Info: 95 Bronco
Post by Kel Fab Creations »
I built this shackle/hanger combo for my bronco. The shackles are 7.25" center to center. The hangers are dropped just enough to fit this size shackles. Only been mocked up. The hangers have been painted semi gloss black. Setup for f150 width springs. I'm selling because I need longer shackles for my spring under setup. These will work great for a spring over setup. $375
Kelly @ Kel Fab Creations
slawson2000
Bronco Info: '87/96... a 20+ year work in progress
Re: bronco f150 shackle hangers and shackles
Post by slawson2000 »
Are these for a 2.5" or 3" spring?
The op says for f150 so that would be 2.5"
-shockseals.com
unless it's a 4wd F-150 which is 3"...
which I believe was Slawson's point.
That being said I'm pretty sure Kelly made these for 2.5" wide springs, but I'll let him say for sure.
Kel Fab Creations
Sorry for the confusion guys. I was un aware that 4wd f150 springs were 3'' wide. These shackles have a 3" spread so they will work on a 2.5" spring. Sale pending...
Kel Fab Creations
Still for sale. The first guy interested has apparently changed his mind...
BIGRED351
Bronco Info: 94 4x4 bronco
Post by BIGRED351 »
Hey Kelly, do you have any ttb44 cores that you would be willing to sell? Jeff 951-306-8112
Kel Fab Creations
BIGRED351 wrote:Hey Kelly, do you have any ttb44 cores that you would be willing to sell? Jeff 951-306-8112
Nope, sorry. Post a wanted ad. Somebody on here is bound to have some.
Kel Fab Creations
$350
Baja
Post by Baja »
Could you tell me where the hanger bolt hole compares to stock? In other words, is it higher or lower than stock and if so, by how much?
Thank you
Kel Fab Creations
The hanger pivot hole is lower than stock to allow for the longer shackle. I don't have a stock hanger to compare to but if you get under your truck and measure from the floor sheet metal directly above the hanger, the new pivot will be roughly 8.25" down from there. Make sense?
Baja
Post by Baja »
Kel Fab Creations wrote:The hanger pivot hole is lower than stock to allow for the longer shackle. I don't have a stock hanger to compare to but if you get under your truck and measure from the floor sheet metal directly above the hanger, the new pivot will be roughly 8.25" down from there. Make sense?
Yes, but are you talking from the bottom of the floor or the rectangular support in the floor, which is right above the hanger location? I just need to kow where to measure from.
Kel Fab Creations
the boxed part directly above.
Kel Fab Creations
Buy, buy, buy. OBO
Kel Fab Creations
$325
Kel Fab Creations
I want these gone. No reasonable offer refused.
Jbfab
Post by Jbfab »
Honestly im interested in the hanger. I hit you up months ago about them on your site but hadn't gotten to that point in the build at that time. The time has come that i could use them. Are you willing to seperate the hangers from the shackles?
Kel Fab Creations
maybe. whats your offer?
Jbfab
Post by Jbfab »
Im gunna write write an offer on this piece of paper, lol. Hows $150 sound to ya?
Kel Fab Creations
sounds good.
