Full float Ford 9.75, detroit locker, 35 spline CM axles
shawn t
Bronco Info: no bronco's but a 1980 TTB F150 and a 1999 2wd F150 soon to become mated together!
Post by shawn t »
I have a Ford (Sterling) 9.75 for sale. Same base axle as Raptors have.
66" wms to wms. 5 X 5.5 wheel bolt pattern.
Retubed with .250 wall DOM by Dutchman Axle.
Detroit Locker. Axle shaft gears resplined (and heat treated) to 35 spline by Jack at CTM.
New Timken Bearing and seals
Yukon 5.13 ring and pinion WITH stock Ford tone ring and crush sleeve eliminator.
35 spline cm Dutchman axles.
Solid Axle cm D60 welded on spindles
Solid Axle cm drive flanges
5 X 5.5" hubs with 5/8" ARP studs, Set up for hub centric wheels. Easily converts back to lug centric.
Rough Stuff fabricated plate diff cover.
ring and pinion set up by Miller Motorsports.
Detroit and r&p have about 200 break in miles on them. Everything else is new.
$3500.
new 13" or 14" X 1.25" rotors, billet aluminum hats and 4 piston CNC calipers, all new, also available. $1500.
new, stock, 9.75 Detroit locker also available. $550.
PM me if interested
