Saginaw Pumps W/ Brackets
S00TLYFE
Bronco Info: IT RAPTOR NOW
Re: Saginaw Pumps W/ Brackets
Post by S00TLYFE »
Bump, 1 460 and 6 5.0/5.8 setups fresh from sandblast this morning.
Stan the Man
Post by Stan the Man »
Killer looking pump brackets and lines. Might have to update my pump lines. These are direct fit? No adapters?
S00TLYFE
Post by S00TLYFE »
Stan the Man wrote:Killer looking pump brackets and lines. Might have to update my pump lines. These are direct fit? No adapters?
So, first off you will lose your factory cooler, other than that they’re plug and play for the most part. The hose end on the slip on side I usually have to ream out a little bit to slide it on easier as it’s just a tad smaller, but with AN fittings that’s the only way to make it work
S00TLYFE
Post by S00TLYFE »
bump, currently have
1 460 setup
3 5.0/5.8
Wanted to show off my setup that Travis just recently built up for me. I’m super pumped on the product and service! Thanks again dude!
freechrisb@gmail.com
Bronco Info: 89 BrF150 on 33x17's no lift. Stroked and built 302, with Mustang electronics
Post by freechrisb@gmail.com »
What about filter and cooler? Thermal bypass; it gets cold -where I live?
S00TLYFE
Post by S00TLYFE »
freechrisb@gmail.com wrote: ↑
Wed Sep 09, 2020 3:31 pm
i dont do any of that stuff but you can adapt one inside on the low PSI side with the factory econoline hoses. I'll glad sell you a pump assembly and you can figure out hoses if you want, there just isnt enough demand for what youre asking for it to be worth my time to R&D
S00TLYFE
Post by S00TLYFE »
Oh, and if you use my hoses with AN fittings, you lose the oem "cooler" but if you run econoline hoses it retains it, hope this helps.
Yes, thank U for U'r response. I actually have van bracket, new RedHead gearbox, and a new/reman Ford saginaw pump -with a remote reservoir fitting on top of it? Where U'r cap would go? This has me kinda wondering; guess go out and get a sealed canister type - mount it on the firewall or something. Only running 33s and no ram; though just want to do it once and it b right. Magna-Pure filter, thermal by-pass and cooler....seems like alot going on here. Thanks for any and all recommendations and help.
S00TLYFE
Post by S00TLYFE »
Fri Sep 11, 2020 1:56 am
i actually just had my first encounter with those weird pumps, you can also just swap it out for one that takes a cap. i think the remote resi ones came off of RVs but havent been able to confirm
S00TLYFE
Post by S00TLYFE »
bump, currently have 5 5.0/5.8 setups ready to go, 2 460 setups
S00TLYFE
Post by S00TLYFE »
bump, two 460 and 4 5.0/5.8 setups
S00TLYFE
Post by S00TLYFE »
bump, just picked up 7 more from sandblast and assembled ready to go
THEJESUS
Bronco Info: 1992 BRONCO XLT
Post by THEJESUS »
Sent text
S00TLYFE
Post by S00TLYFE »
bump, currently have 3 5.0/5.8 setups in stock, anyone who buys before 10 PM PST 1/14/21 ill throw in a free shirt :-) or if you just want to buy a shirt, hit the link in my signature haha
Do these pumps work well with a Hydraboost brake setup and a ram assist inline?
David Wright
S00TLYFE
Post by S00TLYFE »
Wrightracing.net wrote: ↑
Fri Jan 29, 2021 8:45 am
David Wright
Hey Dave,
guys run them with both, no personal experience with it, im happy to sell you all the components minus the pump, because youll need a different one than i sell (Extra port) thats PN BBB INDUSTRIES 7322151, let me know!
David Wright
Hey Dave,
Ok, thanks
David Wright
S00TLYFE
Post by S00TLYFE »
bump, currently have 3 of these ready to go for 5.0/5.8
S00TLYFE
Post by S00TLYFE »
bump, have 3 setups ready to go, brackets are sandblasted, pulleys are sandblasted and powdercoated, reman pumps installed. $300 plus shipping or picked up in Buena Park or South Bay Los Angeles
