Yes, working on a replacement for the stock tire holder that gets bolted to the swing out part. It’s adjustable up/down, sits a little farther out, lower, and has a place to mount a light pod in the center.ChaseTruck754 wrote:The issue I see with the add on tire support step Travis showed is what do you do with a different tire brand, inflation amount or tread wear? You're either going to be heavily preloading the hardware with a newer/more tread/highly inflated tire, or not have the support with the opposite. I guess it is a spare after all, so chances are the same tire will be there for years, but something worth considering.
