Deaver J40 springs and SWP bronco shackles
TurboJoe
Bronco Info: 1968 with 302 Highpinion 44 and 31 spline 9" on 38's and 1996 xlt 351 prerunner in the making
Re: Deaver J40 springs and SWP bronco shackles
Post by TurboJoe »
I may be parting by Baja bug... what are you looking for? I may have what your looking for?
Thanks,
Joe
A lot hahah. It really depends on what you have? I really need a 002 trans, 10" stroke shocks (springs preferred) rear axles hubs etc. Tell me what your willing to part with and if its more on yours or my end we can work it out.
TurboJoe
Post by TurboJoe »
I do have a 002. When I bought it I was told it was a good usable stock trans. I would want to pull the bell housing to check the ring gear to make sure you wont get junk. If I part out the bug I won't be needing the 002. I also have a 6 over beam with tweeds arms and 10" towers set up with leafs and dual adjusters cycles 14"( close to $1200 in it ). Mild steel plate 3x3 arms And wide 5 disc brakes all around. I feel the trans would be a straight across trade.
Let me know what you think or what you need,
Joe
I can get a good 002 trans for 350. I can do the 002 bus trans and a hundred fifty.
TurboJoe
Post by TurboJoe »
At this time I cant put cash on top. If there is other parts I may have something though that would work for both of us?
Joe
What style arms are they? Are the stock or extended? Depending on the outcome I may just trade for other parts and we can talk about the trans separate.
TurboJoe
Post by TurboJoe »
The arms are 2 1/4" longer and 1" wider with 300m link pins.
How about the beam and arms/ link pins?
How about the beam arms n link pins?
TurboJoe
Post by TurboJoe »
You would get beam with bushings, Arms And link pins. Anything you can put on top Bronco stuff or otherwise?
Thanks,
Joe
It depends on condition of the parts. I have some other parts available
TurboJoe
Post by TurboJoe »
Parts are/were new. Baja didnt get finished when I bought the bronco.
Joe
TurboJoe
Post by TurboJoe »
Oh and leafs come with too...
Joe
What else are you looking for?
TurboJoe
Post by TurboJoe »
What do you have? Im looking for Bronco parts or fabrication supplies.
I've got a a rear bench seat with a chase rack and used harnesses, rear bumper with spare tire carrier and more. My bronco is torn apart.
TurboJoe
Post by TurboJoe »
Ok Im sure we will figure something out... Ill get the Baja on the lift this Friday and pull your parts. Maybe meet over the weekend?
Joe
Sorry gentlemen but sale pending.
TurboJoe
Post by TurboJoe »
With me right?
Sorry man a guy handed me cash money.
