That just puts the bending moment for the cage structure in the large span on the rect. tube between where the cage tube lands on it and where it bridges over the frame.
*edit* just looked closer & saw the down tubes to the frame at a diagonal. These will help for sure. But IF rolled the thing will want to bend the rect. tube between where these hit & the down tubes of the cage hit. It breaks up the load path from the tube down to the frame. Hopefully that is at least .125" wall rect. tubing.
ChaseTruck754 wrote:That just puts the bending moment for the cage structure in the large span on the rect. tube between where the cage tube lands on it and where it bridges over the frame.
Yes, DOM down tubes to the frame, and the square tubing is 1/4" thick. I'll be surprised if thats the weak spot on the cage.
ChaseTruck754 wrote:Looks good, but what is the reason for the rectangular tubing/base on the frame. Is this something required by the CORR rules or something?
You should be more than fine at .250". It was just a design I hadn't really seen anyone do before so I was trying to figure out the reasoning behind it.
ChaseTruck754 wrote:You should be more than fine at .250". It was just a design I hadn't really seen anyone do before so I was trying to figure out the reasoning behind it.
Midwest thing.
Scored some gears, shocks, and other things for the Stock Truck at the MORR swap meet. Formula 4 scored some beadlocks, and more misc. stuff.
It was good to meet Erik (ESHALLBETTER) at the swap meet, along with the U-Weld crew, and the original builder of the bronco.
Got the motor in the stock truck, along with completely rebuilding a coil bucket.
ESHALLBETTER wrote:It was good to meet you all as well! Good luck as the build progresses and ill get you some prices on the parts you need!
Sounds good! Just PM me.
Thinking of front suspension set up along these lines, what do you think?
Crappy pic of Trev's coil bucket surgery. Tubes will come off the engine cage to the top of the bucket, but making the bucket look stock was the trick. Still needs to be welded on the inside. Took him about 6hrs. I think he pulled 'er off.
ChaseTruck754 wrote:Are you allowed to cut up the stock bucket in your class? If so I'd cut & plate the stock bucket to move the shock up closer to the coil.
We cannot cut it up, but we could move the shock closer.
Crazy idea, but that shock fits into the hole on top of the bucket, would it be the best setup stuffing the shock inside of the coil (hillbilly coilover?) if we could figure out how to mount it?
The coil will be fixed top and bottom so it will be forced to bend as it travels the suspension arcs. Make sure to check for interference as the suspension cycles. I would try and put it right behind the coil and in the bucket.
The truck as she sits now. Getting the front mocked up for building the engine cage. Sadly I'll be missing out on some work this weekend because of Prom. Darnit.
Comic relief, found this Rubber Duck in the '72 I think. No one really knows for sure, but in 3 garage moves, he hasnt been lost yet. He's our mascot.
