"TrophyFJ" Build. Ls3 powered TTB FJ
trophyFJ
Bronco Info: I'm building a FJC with TTB front suspension, 4-link and a Ls3.....came here to do research. Thanks
Post by trophyFJ »
Yup I'm crazy. I've always thought out of the box why start now?
it will be as it reads in the title.....pretty much...
...yes.....I could make my life easy and just build/bought a prerunner.....but what fun is that?
Plenty of nice pre-runners already built running around socal for sale.....that said, I'm in love with my FJ.
So Fuck it.
I always seen built Bronco's and really like them and considered them initially but in the end the FJC caught my eye back in 2010 and I got the right deal.
I enjoyed it as my "work/daily driver" for many years.....many offroad trails, trips, adventures and miles were enjoyed.
I found myself driving faster and faster offroad....which of course created a few "oh shit" moments and a cooled it and realized it was time to re-think things.
At the same time a side business I started went from zero to sixty really fast and in 2 years now we have 4 CNC machines and ship my camera accessory inventions all over the world.
Which is kinda important when you wanna go fast as we all know......speed costs money.
So.....I ended up at a shop in riverside that had just completed another serious FJ with a good reputation.... and to make a massively Long story short.......
8 Months later.... very little had been done and one day the doors were closed (massive shop) and the security guard gave me a phone number to call.
Luckily I dodged a bullet to the head. Thankfully one of the partners in the business employed a mediator and we were able to come to a fair agreement.
I got a fair financial resolution and I got my truck back (in pieces) but in the end I was more glad to exit that mess.
Basically they had started the cage and fabricated the front ARMS.......but many things were not adding up and since I was able to essentially do a "re-set" on the build, I started to re-evaluate a few key things. especially the front suspension.
In any case, the truck is in the very talented hands of Jordan Knudert ( @dertco on IG) in Las Vegas now and we have a plan and are back on track. Jordan is a talented fabricator and one of the best suspension tuners around. He tunes Strobel TT and has worked on BJ baldwins suspension also.
__________________
So the plan.
-Toyota FJ body/frame/soul
-GM Performance LS3 built by Mullenix racing engines with their stage 3 cam kit.
-4L80 with 300m output shaft/4130 forward hub built by Culhane
-Atlas2 transfercase 300M input and HD case.
-Ford Bronco TTB D44 front end.
-KING shocks
-4-link rear with 55" links.
-37" tires
So why TTB?
Well after thinking about this alot....
The problem with the a-arm solution we were working on was always be CV angle. The weak stock front FJC diff....etc. the other shop had some ideas on how to address those issues but everyone that has a LT FJ has suffered from lots of CV issues. He was thinking we would use a tundra front diff and a few other crazy ideas. Solo motorsports does have a 19" LT kit for Tacomas that uses a 930 innerCV and Dana44 outer u-joints....people I talked to usually strap it at 17". The Arm that were built for my FJ were cycling 17" at the spindle face. So should of ended up just about the same as the solo kit...around 18-19".
RCV cv's are megabucks. Cv's in general are expensive and failure prone when used in these extreme uses.
That and there was alot left to be figured out to make those a-arms they made work....and the designerfabricator was now out of the picture.
So I fell back on one of my original ideas.
Putting a Ford TTB front end on my FJ.
Why? I dont have to preach to the choir here in GFB forum but a few things sway'd me....
TTB has lots of the strength of solid axle with the ride of IFS design, it's rather "easy" to get 20" travel and still be 4wd capable for when you need it. 37" tires, 550ish HP will be hard on the dana44 u-joints then again most of the time I will be in 2wd. When I do use 4wd it will be a more controlled a smart way. That said d44 u-joints are dirt cheap compared to broken CV's. From what I have read u-joints will fail before I brake axles in a TTB.
There are hundreds of very heavy Bronco pre-runners running TTB front ends with 35,37" tires and the D44's actually hold up quite well(AFAIK). Beams have been used for decades off road and have a proven track record and history and when built right proven winning performance.
I was tempted to actually I-beam it but wanted to keep it 4wd, keep some of the "fj-ness" but it was never meant to be a crawler...but it will be nice to get out of silt beds and will come in handy running fun trails out there with my friends, camping with my buddies. Basically I just want to be able to do the same kind of trails I did with my FJ before, which I think I should be able to do.
I might have some "haters" for all the "mixing" I'm doing .....but in the end I'm the one building and paying for my version of my offroad dream machine. So wish me luck. :D
I joined the forum to read up on TTB see everyone's builds and learn what I can.
Also, The Bronco is actually a decently similar to my FJC for comparison on how it might perform when done. So it's a good measuring stick how what to expect from my finished result.
Stock 4th&5th gen Bronco wheelbase? 104.7"
Stock 2010 FJC wheelbase? 106"
So despite the FJC "looking" smaller than a bronco...In stock form it's actually just a bit longer.
That said we are stretching the wheelbase as much we can. Not sure where we will end up. Maybe 110ish? Not sure what Bronco Pre-runners usually stretch their wheelbases too...
For comparison to other popular pre-runner trucks
So a regular cab Tacoma is 110"
late model Ford Ranger 111"
So it's not so horrible.....no doubt the "short" wheelbase will limit my ultimate top speed thru whoops as things start getting a bit "loose" above 60mph.....but with some expert tuning I think I should be able to push it pretty hard.
But then again I'm not trying to build a competitive serious racetruck.
lets face it......60mph+ thru whoops is enough to get my blood flowing and bring a smile to my face.....
....and with expert tuning.....lets see how it will do...
In any case I'm excited to find out.
_____________________________________________
Just a guy with a crazy idea. @trophyFJ on IG.
2010 FJC Future desert racer and desert hooligan.
trophyFJ
Re: "TrophyFJ" Build. Ls3 powered TTB FJ
Post by trophyFJ »
So the rear end....
We taking a 2014 Toyota Tundra crewmax rear end. It is much bigger than previous Tundras at 10.5". Bigger rear brakes and axle shafts too of course. Going to be one strong rear end....ready for the abuse I will be dishing out....
The old shop trussed the axle housing....but once Jordan looked at it we started seeing many things we didnt like and so he is actually cutting off all the truss and doing it over again.
anyways this is what it looked like,
The tear down...
If you need or know anyone who needs ANY stock parts lets me know. Interior plastic parts, headliner and complete drivetrain is for sale
The cage taking shape.
Deft racing Has contributed a badass fiberglass vented hood, way lighter than stock and works on factory hinges and hardware.
trophyFJ
Post by trophyFJ »
lower link mount.
Tack'd together enough to link her all up and finally cycle her for the first time and start to see how everything lines up.
trophyFJ
Post by trophyFJ »
32 gallon Jaz cell
Here is a shot from when I made my "exit" from the first shop in riverside. The whole thing is very disappointing to say the least. But it was for the best, I am much happier and more confident in the direction we are headed now.
My family tow rig pulling its first load.... Putting the BMW TwinTurbo Diesel to the test, on my way to vegas to continue the project and get it done ....
fast forward a few months...
Mullenix builds the engines of many winning desert race trucks here in SoCal. Justin Oquendo, Nick Isenhour, Kibbetech etc...
Time to give the beast a proper heart...
Brand new GM performance LS3 6.2L of power. bye bye 4.0... Thanks to James and Thomas at mullenix racing for working with me on this and now it's time to get to work!
trophyFJ
Post by trophyFJ »
It has begun! @Dertco laying down the first main piece, the main TTB crossmember. Fabrication has begun, and it looks on point. As you can see in the background my truck is in good company. Hopefully some of it will rub off on the FJ ....
damon1272
Post by damon1272 »
Looks like a very cool project. Can't wait to see it done. Love the FJ's
I only had time to skim, but... YES! This is rad. I dig it!
Welcome and sweet!
I'll be following this one. Looks like your radius arm mounts will be touching the rear link mounts haha
trophyFJ
Post by trophyFJ »
cs_drums wrote:I'll be following this one. Looks like your radius arm mounts will be touching the rear link mounts haha
hehe....yeah pretty much.
Lots of parts ordered....waiting for stuff to come in.....
XTate
Bronco Info: 95 Bronco stock not for long
Post by XTate »
This is crazy shit, a Pinto would have made a better base platform.
XTate wrote:This is crazy shit, a Pinto would have made a better base platform.
Here you go..... http://www.pirate4x4.com/forum/general- ... uncer.html
damon1272
Post by damon1272 »
With respect to the Pinto, drugs will make you do strange things. That said lets see some more pics of his FJ. Thing is awesome.
XTate
Post by XTate »
The Fab work on your FJ, is clean, real nice. But that Pirate Pinto is dirty, real dirty like a porn star. Not meaning to jack your build thread.
Interesting about the wheel bases from bronco to fj... Would have thought the fj was much shorter. Kick ass concept, I like it!
trophyFJ
Post by trophyFJ »
@dertco has been busy designing my new lower links. If you need some hit him up he makes them in a few lengths already, mine will be 55" long.......if your following the build and wondering where are those sweet links you saw in prior build pics, well part of the deal I made to get the truck out of the last shop is that they wanted to keep the lower links. So we made a deal and they stayed behind. It was for the best really as I'm looking forward to these taking shape under the same skilled hands that are drawing them. Looking forward to when he sparks it up and starts melting some metal.
Here is a shot from solidworks
trophyFJ
Post by trophyFJ »
Early Christmas present!
Shit is getting real this week over at @mullenix_racing_engines hopefully I can stop by their beautiful new shop and see them work their magic....
A fresh create full of horsepower.
American V8 POWER......err.....oh wait.
Hecho en Mexico Cabron!!
Naturally this officially makes my complete stock drivetrain up for sale!!
(2010 55k miles, 4.0 double vvti, auto tranny & transfer case) is Make me an offer!!
Original owner dealer maintained and never a problem. Amazing drivetrain for someone.
My new 6.2 LS3 waiting its turn in the @mullenix_racing_engines engine room..... it's won't stay stock for long..... stay tuned....
The funny thing is the motor cost me the same as if I bought a TRD supercharger kit. Yet it will yeild more than double the HP&tq. The kicker is might even get better gas milage than my stock 4.0.
All in all, money well spent in my book.
SC the 4.0 v6 stresses it out and for sure decreases reliabillity. Ls3 is bulletproof, plus it comes with a fresh 50k miles warranty!
Sweet!! This thing is going to be badass.
XTate
Post by XTate »
LS3 best horsepower deal for the money, you will love it.
trophyFJ
Post by trophyFJ »
Great feeling coming home after a tough week at work to shiny race truck parts! Let's see what's inside....
Atlas came in! Thanks to advanced adaptors for supporting the build. They have been great to work with.
Shift knobs, 4L80e adapter, cable shifter etc..
Yes I went with the Heavy Duty case ...
300M input/32spline , 2.11:1 HD gear set
one more piece to the puzzle...
