Big Bertha
Big Bertha
Some people on FSB wanted to see some more on this thing but there was not anywhere to post it.
It is a 97 Ford F250HD Crew Cab short bed. 460 engine with a E4OD trans, 2wd. I've had it for about 5 or 6 years now. I am currently redoing the suspension. Truck has a Sterling 10.25 with 4.10 gears and a factory limited slip, H2 wheels with OMF rings, and 37" Toyo M/Ts. The rear end is now spring under with 9" lift national. The pack is a custom pack with about 12 leaves and 3" wide.
Current plants are custom beams and radius arms with D44HD ends, SAW 2.5 shocks all the way around, Giant engine cage (mounts 16" coil over on the front), fiberglass front and rear, cage, +4 per a side front and rear.
- Silverslk
Re: Big Bertha
Thats a nice truck!!!
- Rednek Renegade
Re: Big Bertha
The rear still sits a little tall for my tastes... but I won't know until I do the front end if I can get away with it lower.
Tuckin 37s yo!
Tuckin 37s yo!
- Bronco Broker
Re: Big Bertha
Man I like this truck. I'd love to see it with a utility bed and used a chase rig. Very cool.
Re: Big Bertha
Doc Glass has one with a Powerstroke.BajaBronco13 wrote:Man I like this truck. I'd love to see it with a utility bed and used a chase rig. Very cool.
Re: Big Bertha
Finally did some work to the beast. I put the glass I had on the front. Rumor is this is the first set of fenders Glassworks made for our trucks... It used to be on a certain black extra cab Camburg F150.
Now all I have to do is build beams, radius arms, a bed cage to support the spares and glass, relocate the battery, build a wider rear axle, repaint it, install a 6BT Cummins, and purchase a set of Bilstein shocks for it.
Re: Big Bertha
That glass looks like it fit great !
Re: Big Bertha
It wasn't too bad. The glass had already been professionally installed on a Camburg truck and then body worked and painted. It's not perfect if you nit pick it but no glass is...tcm glx wrote:That glass looks like it fit great !
- Bronco Broker
Re: Big Bertha
Looking good Philo.
Are you going to do the Sterling rear disc conversion?
Re: Big Bertha
Not sure on the rear end yet. It currently has some evil 2" wheel spacers but I need it to be 4" over per a side to mach the front. The problem is a stock LH axle is 37.5" long and no one makes aftermarket axles longer than about 40". So I am stuck with widening one side more than the other or converting it to a D60 style hub that does no protrude as far past the WMS. If I convert it to a D60 style snout/hub I may use new OEM GM/Mopar disks with an integral e-brake. I am not a fan of Caddy style e-brake calipers or not have an e-brake at all. Another option might be Ford F-450 unit bearing hubs with a axle slug combo.BajaBronco13 wrote:Looking good Philo.
I'm also not sure how well it will hold up to a built 6BT Cummins... I plan on installing everything Banks makes for them. My understanding is it will be about 700-800 ft pounds of torque.
- Bronco Broker
Re: Big Bertha
What about a rear end like Ruff Stuff's axles? Sounds like you may need an aftermarket rear end.
Re: Big Bertha
I need a VSS in the rear for now and possibly after the engine swap so the speedo works right. A Sterling center is quite strong but I may be better off with a D80 or equivalent. I'm not sure I want to spend 4K+ on a rear if I can modify my Sterling for about 1K.BajaBronco13 wrote:What about a rear end like Ruff Stuff's axles? Sounds like you may need an aftermarket rear end.
Re: Big Bertha
Did a little work on the truck today. Started the bed cage and battery mounts.
I wish I had more time... I miss driving this thing.
Re: Big Bertha
I'm working on it again...
Re: Big Bertha
thats a nice truck philo, I've never seen a truck like that with glass. Definately a one off truck.
- Bronco Broker
Re: Big Bertha
Looking good Philo. Any chance you can post a side view?
