nubreed71
Post by nubreed71 »
10/13/2016
I stopped by Richer Racing to check everything out in person, Jonny and his crew are killing it as usual. Can't wait to see it all buttoned up!
nubreed71
Post by nubreed71 »
11/21/2016
Just realized I never posted the finished pics from the axle/spring under swap.
I'm digging the new slightly lower ride height. I was able to drop the front ride height as well to match the rear.
The drivers side bedside is @ Autofab right now to get a fuel door pocket glassed on. Last step before I get the fenders and bedsides painted.
Rear axle and springs:
Snagged some 3.0 Raptor bypasses for the rear. With these shocks on there, it's at about 17-18" rear travel.
And swapped the front C/O's over to Fox as well, because OCD.
And the obligatory droop shot:
Also, here's a shot of the third brake light project I've been working on. I cracked an OEM housing, had a steel plate cut out to cover where the lens used to be, and then retrofitted it with 2 red LED Rigid dome lights for the third brake light, and a high power Rigid A series white LED for the cargo light. I'm loving the upgrade. Much better on the third brake lights, and the cargo light illuminates the bed like it's daytime.
nubreed71
Post by nubreed71 »
11/21/2016
I wired up a little Baja Designs light with built in switch for the under hood light as well.
nubreed71
Post by nubreed71 »
12/6/2016
I ran out to Ocotillo Sunday afternoon for a little shakedown run with a buddy since I knew this would probably be the only weekend I'd have a chance to get out before the holidays. Stoked with how the truck ran. The rear shocks could use a little tuning, and a couple new bypass adjusters (more on that later), but the spring under felt great, and I was really happy with the new gear ratio in the rear axle. So glad I went to 5.14's.
Snagged a quick shot as we were trying to figure out why my buddy's rig decided to shut down. Not sure what it was, but we fiddled with the inertia switch and then she fired right back up, so off we went again.
Then we ran out towards the railroad tracks and blasted along that road for awhile. I love that section...so fast and nice and buttery.
Then we hooked left over towards Superstition. Stopped for a hydration break:
Then we headed up the base of Superstition, but ended up stopping after an unforeseen drop off caught us by surprise. After a quick safety meeting, I parked my rig and hopped in my buddy's Bronco to head to the top and eat some lunch.
Pics of said unforeseen drop-off:
That's my truck down there somewhere. Kind of a funny little where's Waldo shot.
After grabbing a bite, we headed back down, grabbed my truck and headed back towards the railroad bridge/wash. Grabbed a couple glamour shots there.
I'm kinda laughing since I noticed the graffiti once I loaded the pics onto my computer. Oh well...I guess i won't frame this one after all.
All in all a great little half day shakedown run, got in about 50-60 dirt miles. The truck ran almost flawlessly...the only carnage on my rig was a couple bypass adjusters that ended up being a little too long. When Richer cycled the rearend it was with 3.0 smooth bodies on there, and we swapped these on after the fact. We suspected that they might hit, and sadly they did. Not sure how I'm gonna address this since I really want to keep these shocks on the truck. I may look into converting them to remote resi instead of piggyback, and then flipping them around so that the bypass tubes are hanging off the front of the shocks instead. No idea if that's possible, but worth a shot.
And here's a little readout of our run...kinda cool to see it all on the map.
nubreed71
Post by nubreed71 »
12/17/2016
Don't worry, the BTR's aren't going anywhere....just some temporary shoes while the BTR's get machined so I can run proper lug nuts. Those projects look friggin yuuuuuge.
nubreed71
Post by nubreed71 »
1/8/2017
Been working on some small detail projects lately. First up was having some metal straps made to sandwich the fiberglass bedsides between the OEM steel bedrail and said metal straps. As always, the boys at Richer killed it on these things.
Added a few tie down loops while we were at it.
A friend of mine made a set of these fuel tank straps for his rig, and I liked em so much I asked him to make me a set.
nubreed71
Post by nubreed71 »
4/24/2017
Not a super exciting update, but I've been working on some little ticky tacky projects while I wait for some bigger stuff to get wrapped up.
I noticed my spare was getting a little more sun than I'd like, so I grabbed this cover from Smittybilt and then had it modified to work with my tire spinner.
nubreed71
Post by nubreed71 »
5/6/2017
Super psyched to have a truck that's all one color again!
nubreed71
Post by nubreed71 »
7/8/2017
Snapped a couple glamour shots the other day:
And then got my lightbar back from powdercoat and got the lights all bolted up. Damn these things throw off a lot of light. Can't wait to get a nighttime shot later today.
nubreed71
Post by nubreed71 »
9/19/2017
I finally finished converting all my lights to Baja Designs. I was able to get creative and use a faceplate that was intended for the headlight on a dual sport bike and adapt a set of Squadron Pro's to the holes already cut in my rear bumper that were originally for Rigid/China LED Pods. Pretty happy with how it came out.
Imagehttps://flic.kr/p/21993tW
Imagehttps://flic.kr/p/21e5Fbg
Imagehttps://flic.kr/p/21gJsbF
nubreed71
Post by nubreed71 »
11/2/2017
Finally got my headliner/visors reupholstered in gray tweed to match my seats. Also broke down and shelled out the cash for some Coverlay reproduction door panels. I had them ship the panels disassembled and then had my upholstery guy do some panels in tweed also. Stoked with how it all turned out!
Wow
Salttoy
Post by Salttoy »
Taylor, Thank you for re-posting all of your build pictures. Your truck is truly inspiring.
nubreed71
Post by nubreed71 »
For sure! I couldn't let the build thread die :-) Plus, it felt good to delete all my pics from my old Photobucket account and give them the finger.
redrdr67
Bronco Info: 1999 F350, 1999 E350, 1995 F150 2WD
Post by redrdr67 »
Looks great!
Are your new panels light grey or medium grey?
nubreed71
Post by nubreed71 »
The door panels are the light gray color from Coverlay. I'm glad I called them and had them send me swatches because if I had to guess, I would have bought the medium gray.
zachwabbit
Post by zachwabbit »
Looks awesome a man! I'm gonna have to add those door panels to new parts I want but can't afford right now lol
Potato.
S00TLYFE
Bronco Info: IT RAPTOR NOW
Post by S00TLYFE »
tweed was such a bitchin upgrade dude im trying hard not to steal a ton of ideas for my truck from yours
nubreed71
Post by nubreed71 »
Thanks man! Glad to see my old shocks are getting used again. Your truck is looking awesome!
S00TLYFE
Post by S00TLYFE »
nubreed71 wrote:Thanks man! Glad to see my old shocks are getting used again. Your truck is looking awesome!
appreciate that, definitely gonna be hitting you up for your lights and I have some questions about a few other things youve done. ill be in touch.
