Big Bertha
Re: Big Bertha
ahh thats right sorry i forgot it was 2wd.
Re: Big Bertha
I started on the bed cage... soon I will be able to dispense with the zip tie license mount.
Re: Big Bertha
Thanks alot...... now you got me thinking about building a tow rig. Good job on yours so far!! I'm thinking the same kinda thing, crewcab shortbox with a 5.9 cummins.
Re: Big Bertha
My buddy Reg at RCTS Canada tells me Cummins are a dime a dozen up where he lives in Calgary. Been trying to get him to bring one back for me.BajaDale wrote:Thanks alot...... now you got me thinking about building a tow rig. Good job on yours so far!! I'm thinking the same kinda thing, crewcab shortbox with a 5.9 cummins.
Re: Big Bertha
philofab wrote:My buddy Reg at RCTS Canada tells me Cummins are a dime a dozen up where he lives in Calgary. Been trying to get him to bring one back for me.BajaDale wrote:Thanks alot...... now you got me thinking about building a tow rig. Good job on yours so far!! I'm thinking the same kinda thing, crewcab shortbox with a 5.9 cummins.
They are, especially the old 12 valve 5.9 you almost can't give them away. I was thinking about building it 4wd and running 1/2 ton dana 44 front end with the 8 stud knuckle and brakes. Keep us updated on yours! I love it!
Re: Big Bertha
Spent some time this weekend working on the radius arms. I started these a couple of years ago with a bushing style mount. I decided to change over to a heim. I ran out of material though so I need to go buy some more in the morning.
Re: Big Bertha
Lately I've been thinking about converting the truck to 4wd... I'm just not sure how well D44/D50 stuff will last with a Cummins in the truck.
I was thinking of using a D50 center, D44HD outers, and D44 1/2 ton style pivots in a beam that is 4" over.
4WD lets me be lazy and has spoiled me.
Re: Big Bertha
That'd be one bad machine. Only, how will the transfer case and hubs hold up to the torque of that cummins?
Re: Big Bertha
philofab wrote:Lately I've been thinking about converting the truck to 4wd... I'm just not sure how well D44/D50 stuff will last with a Cummins in the truck.
I am with you on that Philo... I was just emailing Chris back and forth about him doing the same in the 4 door Bronco. He suggested and I think it is a great idea. I wonder from the drivetrain if it is harder, or easier on the whole truck. The idea of having 4wd and pulling instead of just pushing through whoops always makes it seem better. I love dricing my Bronco in the mid size whoops with 4wd... feel like I have better control.
Re: Big Bertha
Drive like the experienced desert 4WD guys do and the Cummins wont break anything. Experience shows the D44 will survive it you are in 2wd for the whoops and jumps. Not for rock crawling but for go fast.
For more margin just use the open D50 which is surely stronger.
The only time I use 4WD in the desert in in the silt, deep sand and the crawl over the summit. Never in the whoops.
Do you need 4wd - for sure. I am sure when you get bogged down in the silt or the sand washes I will not be able to tow you out. I have tried to tow TTs and C8s and it nearly impossible due to the weight of the stuck truck.
2WD sucks in the desert fro a heavy truck.
Paul
Paul
Re: Big Bertha
Haha, I know. The truck does really well going forward due to a lot of anti squat and good weight bias but it will get instantly stuck in reverse. I think I would like 4wd for piece of mind. I'm thinking the 300 or pounds that 4wd adds won't affect a lot in the long run, It might put me over the 7,000# mark though.PaulW wrote:2WD sucks in the desert fro a heavy truck.
- Bronco Broker
Re: Big Bertha
I've given this lots of thought and have exchanged a few emails with Jeremy aka 78Crew on RDC, who owns the crew cab long travel prerunner. He's running a Dana 50 extended with built E4OD and an Atlas. I'd like to go that same route. My Bronco will easily weight over 7,000 pounds I estimate so 2wd just won't work for my truck.
Re: Big Bertha
Good luck keeping it under 7k Mine fully loaded goes 8200
PW
PW
Re: Big Bertha
What style pivots is he running? My crossmember has the same pivots as a Bronco and the sheet metal is thicker. I always thought the D44HD/D50 pivots would restrict travel but Baja250 has proven otherwise.BajaBronco13 wrote:I've given this lots of thought and have exchanged a few emails with Jeremy aka 78Crew on RDC, who owns the crew cab long travel prerunner. He's running a Dana 50 extended with built E4OD and an Atlas. I'd like to go that same route. My Bronco will easily weight over 7,000 pounds I estimate so 2wd just won't work for my truck.
I don't know what t-case I would run but I do plan on running a Dodge transmission (74RH most likely.) unless I can find a Alison that will work.
Re: Big Bertha
Well, my truck weighed less than 6,500LB with a carpeted bed, full tanks of fuel, a fiberglass tonneau cover, and the current 37" tires. I need to go weigh it again with the spares on the back.PaulW wrote:Good luck keeping it under 7k Mine fully loaded goes 8200
PW
The Cummins should only add 300 pounds or so.... and the only weight the 4wd will add is front pumpkin, driveshaft, and t-case.
Re: Big Bertha
A friend of mine is (maybe already has) tossing an F250 TTB in the trash. If you're interested I can ask if it's still around.
Re: Big Bertha
Please do. It would be nice to have around as I figure out if I want to go that route.SteveG wrote:A friend of mine is (maybe already has) tossing an F250 TTB in the trash. If you're interested I can ask if it's still around.
Re: Big Bertha
He's still got it but it's getting scrapped soon. I can go pull it off the frame but don't have anywhere to store it... it would need to go away as soon as possible.
It's a leaf spring TTB like BajaF250 was originally.
Re: Big Bertha
I'll be in Torrance this weekend. I'll see how my schedule is for driving up to Arroyo Grande. I think your about 180 miles north of where I'll be at.SteveG wrote:He's still got it but it's getting scrapped soon. I can go pull it off the frame but don't have anywhere to store it... it would need to go away as soon as possible.
Re: Big Bertha
Hey do you still want my leaf springs and coil buckets?
