1990 Ford150 4x4 "Bajamobile"
Re: 1990 Ford150 4x4 "Bajamobile"
interesting approach with the plate tie them together, curious to see how it gets finished out.
- funinthesun95
so the wipers will clear?
- Turf Tamer
- Bronco Info: 1990 F-150 396 stroker w/camper shell. Its got KING's bra!!!
- Bronco Info: 1982 c6, 9" gears, lockers,
Sick engine cage
- Turf Tamer
A few upgrades on the accessories side. My guy is taking his time but at least he does nice work.
¯\_(ツ)_/¯
- Turf Tamer
That is some nice tube work
- Turf Tamer
What spring combos are you guys running. Accutune set me up with a 250/350 combo, but it seems a little light.
¯\_(ツ)_/¯
I think I ran 350/450 on my '94 extracab. 250/350 seems light.
Walter, I had always been told 350/450 were the magic numbers. I did a bunch of research before going with that coil set up. Probably slightly different with that nice new bypass set up, but I'm not sure I'd venture too far off that mark. Especially considering the way you flog the living %^&* out of her now. Also consider the added weight of the cage. It may still be right on the mark. Those old coils have to be absolutely flogged by now.
- Turf Tamer
Is that what was on the truck? The coils were all worn out and the markings were gone.SC150 wrote: ↑Fri Jul 10, 2020 9:59 pmWalter, I had always been told 350/450 were the magic numbers. I did a bunch of research before going with that coil set up. Probably slightly different with that nice new bypass set up, but I'm not sure I'd venture too far off that mark. Especially considering the way you flog the living %^&* out of her now. Also consider the added weight of the cage. It may still be right on the mark. Those old coils have to be absolutely flogged by now.
¯\_(ツ)_/¯
Yup. 350/450.
- Turf Tamer
The engine compartment is just about done and the truck is running again. We got a new driver door and quarter panel installed and the body lines are nice and tight again. Interior work should start soon.
¯\_(ツ)_/¯
- Turf Tamer
- Turf Tamer
looking sick!
- Turf Tamer
Well I’m being told my 8.8 it toast. Looks like I’m going to a 9”.
¯\_(ツ)_/¯
- Turf Tamer
You guys think I need to go full floater or can I get away without?
¯\_(ツ)_/¯
Depends on tire size and how hard you drive it along with your power output and how much you want to spend. They're good insurance but definitely at a cost. If it were me, I'd do a 9" no problem.
