1991 Ford F-150
Re: 1991 Ford F-150
It's got OD so 4.10 is ok. The 300 doesn't rev like a small block and makes power way down low, so 3.73 or 3.50 could work too. Depends on what you want it to be like on the street and at the pump.
I run 4.56 / 37" with my M5R2 and a little stock 302. It has enough power to get around. I can comfortably cruise at 80-90 mph on the freeway too.
- Firetwig
- Bronco Info: 1978 Ford Bronco 1996 Ford Bronco
Re: 1991 Ford F-150
Well, as an indication... I drive my truck every single day. To work and back, to play and back... I drive my Firebird to car club etc. Mustang up and down the road once a week. Bronco to town and back once a month.
1991 Ford F-150
What do you have now? 3.08?
- Firetwig
Re: 1991 Ford F-150
2.73s and I love them honestly.
1991 Ford F-150
Don't go lower than 3.50 then.
- Agui-E7TE
Re: 1991 Ford F-150
Numerically lower or lower gearing?philofab wrote:Don't go lower than 3.50 then.
3.55, 3.73, 4.10, 4.56? or 2.73, 3.08, 3.23?
Edit: Nevermind, just realized you meant to say numerically lower (higher ratio) than 3.50.
- Firetwig
Re: 1991 Ford F-150
I found 2inch coils and that is about it. Maybe make the damn truck level...
http://www.summitracing.com/parts/SJA-1 ... l%7cCUSTOM
Those? ---^^
Oh and these
http://www.summitracing.com/parts/TFY-22811/
Those don't need any other parts I don't think.... Just coils fit right in and add some Bilsteins...
Those? ---^^
Oh and these
Re: 1991 Ford F-150
you'll need some big alignment cams with the coils.
- Agui-E7TE
Re: 1991 Ford F-150
You'll need alignment cams. Not sure what size you'll need since your truck is 2WD. As far as how high you can lift it and still be able to have it aligned, I'm not sure what the limit is for a 2WD... Philo might know this though.
Re: 1991 Ford F-150
I've been able to fit 3 degree with some grinding on the knuckle and beam.Agui-E7TE wrote:You'll need alignment cams. Not sure what size you'll need since your truck is 2WD. As far as how high you can lift it and still be able to have it aligned, I'm not sure what the limit is for a 2WD... Philo might know this though.
