95 f150 4x4
Re: 95 f150 4x4
Is yours for sale Andy?
Re: 95 f150 4x4
yes - his is.
Re: 95 f150 4x4
steve-oh wrote:Alright, pulled out and cleaned up some beams, theres a flat spot on the bottom of the ds beam, i marked a dotted line threw where the cut would be, its at 90 degrees to the flat spot....am i thinking correctly here? My plan is to make a jig to keep things inline just doing a little research now...
If you cut there, what are you planning on doing with your radius arms?
Re: 95 f150 4x4
I'd just throw extended beams and coil overs at it and spool the rear and what you can't crawl over just fly over. Your truck has the potential to scare you.
Re: 95 f150 4x4
Actually wrong thread for that comment sorry about that.
- Silverslk
Re: 95 f150 4x4
Yes, it is.hobbyturnedobsession wrote:Is yours for sale Andy?
- steve-oh
- Bronco Info: 93 xlt,5.0 caged, extended beams work in progress
Re: 95 f150 4x4
Thanks ill check it out.Silverslk wrote:In my build thread are pics of the 3.5 over beams I have in my garage to put on. Might give you some ideas. they are good pics.steve-oh wrote:Alright, pulled out and cleaned up some beams, theres a flat spot on the bottom of the ds beam, i marked a dotted line threw where the cut would be, its at 90 degrees to the flat spot....am i thinking correctly here? My plan is to make a jig to keep things inline just doing a little research now...
- steve-oh
Re: 95 f150 4x4
Doing some extended before arms, and that would push them away from the frame and should give me some more clearance i would think as rmc pointed out to me.Travisfab wrote:steve-oh wrote:Alright, pulled out and cleaned up some beams, theres a flat spot on the bottom of the ds beam, i marked a dotted line threw where the cut would be, its at 90 degrees to the flat spot....am i thinking correctly here? My plan is to make a jig to keep things inline just doing a little research now...
- steve-oh
Re: 95 f150 4x4
Radius arms not before arms, smart phone is not to smart.....
- steve-oh
Re: 95 f150 4x4
Your beams are extended after the radius arm mount holes correct, and they where made by travisfab?Silverslk wrote:In my build thread are pics of the 3.5 over beams I have in my garage to put on. Might give you some ideas. they are good pics.steve-oh wrote:Alright, pulled out and cleaned up some beams, theres a flat spot on the bottom of the ds beam, i marked a dotted line threw where the cut would be, its at 90 degrees to the flat spot....am i thinking correctly here? My plan is to make a jig to keep things inline just doing a little research now...
Re: 95 f150 4x4
Not sure about where they were extended but not made by Travisfab. If I remember right they were made by BTF. Note - this is not the "Blue Torch Fab" that sells fab parts on the net, but rather a local fab outfit run by 2 brothers.
Re: 95 f150 4x4
My beams were cut after the radius arm hole and finished by Threat Motorsports
- steve-oh
Re: 95 f150 4x4
I was checkn out your build thread and seen where you cut yours, if you dont mind passing along the info what was wrong with the angle of the cut? My thinking is it has something to do with keeping the axle plane correct?Travisfab wrote:My beams were cut after the radius arm hole and finished by Threat Motorsports
Re: 95 f150 4x4
I cut it straight up and down and it should have been cut at an angle
- steve-oh
Re: 95 f150 4x4
Anbody running a 4r70w trans with a 400-450 hp windsor? I'm not planning on keeping the 5.0, but if the overdrive won't handle that kinda of power without dropping a pile of money into it and a c6 is on the list, ill probably just build a 466 or a 520 for it, any reason other than weight on not running a big block? 500 hp is easy and would be cheaper going that route
- steve-oh
Re: 95 f150 4x4
No more borrowing a bender
- phpaHsJBdPM.jpg (69.47 KiB) Viewed 2818 times
Re: 95 f150 4x4
Nice!!
Re: 95 f150 4x4
Big block with aluminum heads/intake/water pump should be within 100lbs of an iron head small block if I remember correctly...
Re: 95 f150 4x4
The reason we don't here is smog/gas prices (CA). Plenty of people do though when they don't have to worry about smog. FSB is full of big block swaps.
- steve-oh
Re: 95 f150 4x4
I'm going to to just keep the 5.0 in it for now and do the suspension, cage and the inside before i decide on the engine, id really like to build a 520 stroker for it for and easy 600 hp and a whole lot of fun
