Motor dance w/ stock mounts....
NikBraap
Bronco Info: #Bronco777 built by Solo
Post by NikBraap »
In case you wonder how much your motor bounces around with stock motor and trans mounts... I got solid mounts installed after I filmed this.
Dammmnnnn. I want to see the same shot with the Autofab mounts
I wonder how much shock those stock mounts are absorbing.
Deslboy
Re: Motor dance w/ stock mounts....
Post by Deslboy »
I bought a set of Solo motorsports motor mounts. Well worth the money. Super easy to install too. It took me about 25 minutes to remove the factory ones and install the new ones. I can tell a difference as soon as I started it in the garage.
