uni ball conversions
- Polarcub
I know that its pretty common to convert the pivot bushings on the beam to uni balls but I was wondering if anyone has converted the ball joints to uni balls and what kind of success they had? I am not killing ball joints but if I move forward with a new set of beams in the future I am considering converting the ball joints to unis?
Jeremy
Re: uni ball conversions
Scott is doing that very thing with his set of beams over at Camburg, both upper and lower. I would talk with him. I believe the top is doable but the lower BJ is a bit more challenging due axle shaft clearances. I would beleive it would be similar to their F-150 race spindles.
Didn't the Speed Unlimited "retro" bronco incorporate uniballs?? Check out Speed Unlimited
http://www.speedunl.com/motorsports/projects_mhf150.htm
- Polarcub
I will check out speed unlimited closer I dont remember the retro having them but the MH 150 looks like it does under their projects. I will have to check closer. Will have to see if I can get a hold of scott when this is closer to starting. I am just debating if its worth the headache...it would be cool though...hmmm
Jeremy
Have bms make a set of these with uniball cups.
http://www.blitzkriegoffroad.com/produc ... tb_spindle
I don't think you would want to modify a factory CAST knuckle for a weld in cup.
- Polarcub
maybe if I win the lotto haha....yah the cast material was one thing I thought would be an issue as well.
Jeremy
