Dual Spares
Dual Spares
My Bronco handles so much better with a couple spares in my cargo area. Of course I'd like to gain a little more interior space, so I'm considering doing this setup. I'm just not sure if I like it yet, and especially with 37's! Any ideas?
I'd do something where they bolt in place (no straps) and they would hinge down to the ground to open the tail gate.
- ESHALLBETTER
Re: Dual Spares
I've always liked that set up on that explorer. I think it would be sweet on the bronco. I would make it a two piece though and swing each out to the side, I wouldn't want to lift the thing up and down.
Re: Dual Spares
ESHALLBETTER wrote:I've always liked that set up on that explorer. I think it would be sweet on the bronco. I would make it a two piece though and swing each out to the side, I wouldn't want to lift the thing up and down.
They only problem with the swing out style, is the extra space needed for the hinge and latch. Two 37's, almost touching, will cover about 1" of each tail light.
- ESHALLBETTER
Re: Dual Spares
Tail light schmail light. I would build some brake lights into the bumper/tire rack. Either way it's going to look cool, I would just hate to have to lift 2-37" tires when I need to grab a beer out of the cooler in back! This isn't a DD correct? Not as big of a deal if it isn't used everyday.
- ESHALLBETTER
Re: Dual Spares
I meant to attach this link for you if you do decide to pivot the assembly downward.
http://www.indgassprings.com/tension.html
It would be nice to mount a tension gas strut to help with some of the load. Similar to what Richer did on his old shop truck, just in reverse.
Re: Dual Spares
Yeah I was actually thinking about a strut. It's also not my daily driver
Re: Dual Spares
I don't really see the problem with the dual uprights touching in the middle & being side swung. The hinge (something like a trailer snout & hub I would assume) could go behind the tire if needed, but should be out of the way due to the radius on the tire - right?
For the latches - wouldn't they latch to the bumper & also be in the triangle created by tire's radius?
As for the tail lights being covered - 1" isn't a ton but it may be enough to get you a talking to from the man if you drive it on the road.
Re: Dual Spares
Personally, I couldn't see myself carrying 2 spares, rather 1 spare, a puncture repair kit and compressor or OBA. If you HAVE to have 2 spares, why not have a spare inside on the left, and another on a stronger version of the factory tyre carrier on the outside? The weight woud be balanced left to tright, it frees up some space in the back and still gives you a secure spare if the outside one got stolen.
- ESHALLBETTER
Re: Dual Spares
It's nice when your chasing to be able to carry a spare for your rig and a spare for the race car. I would save the interior for people, gear, coolers, and parts you don't want stolen.
Re: Dual Spares
Assuming the race car has a different wheel pattern, carrying the rig spare inside and the race spares outside sounds feasable.ESHALLBETTER wrote:It's nice when your chasing to be able to carry a spare for your rig and a spare for the race car. I would save the interior for people, gear, coolers, and parts you don't want stolen.
- ESHALLBETTER
Re: Dual Spares
But I want to see how cool the twin spares on the back looks, and that would derail my selfishness.AussieRod wrote:Assuming the race car has a different wheel pattern, carrying the rig spare inside and the race spares outside sounds feasable.ESHALLBETTER wrote:It's nice when your chasing to be able to carry a spare for your rig and a spare for the race car. I would save the interior for people, gear, coolers, and parts you don't want stolen.
Re: Dual Spares
ESHALLBETTER wrote:But I want to see how cool the twin spares on the back looks, and that would derail my selfishness.AussieRod wrote:Assuming the race car has a different wheel pattern, carrying the rig spare inside and the race spares outside sounds feasable.ESHALLBETTER wrote:It's nice when your chasing to be able to carry a spare for your rig and a spare for the race car. I would save the interior for people, gear, coolers, and parts you don't want stolen.
Re: Dual Spares
A 37 will not fit upright, or laid down between the tail gate and the back seat. The pic shows the only way I can carry spares at this point. I plan on doing LONG Baja trips, when you use your first spare, you have no spare! I'm going to have to play around with it to see how I can make it work. Trailer lights may have to happen.AussieRod wrote:If you HAVE to have 2 spares, why not have a spare inside on the left, and another on a stronger version of the factory tyre carrier on the outside? The weight woud be balanced left to tright, it frees up some space in the back and still gives you a secure spare if the outside one got stolen.
Re: Dual Spares
I really like the spare set up on that Explorer. Yeah, the lack of swinging carriers makes it a pain in the butt to open the hatch but it would be a lot harder to make it secure and strong enough. It's a trade off.
I'm thinking about making a similar set up to carry a gas can or two on my Explorer.
- otter
Re: Dual Spares
I have wanted to do dual spares on my Explorer and now my bronco. I think it looks awesome. Here's a fullsize with dual spares.
- wmreartires.jpg (37.38 KiB) Viewed 1571 times
Re: Dual Spares
That's a ramcharger right?
- otter
Re: Dual Spares
Yes
Re: Dual Spares
I like the idea of the dual spare -- on that Ramcharger it looks pretty tough! I personally dont like the idea of the post swing away thing. If it wre
Re: Dual Spares
If it were me I would make the pivots like this... http://protofab4x4.com/products.php?ID=00&ID2=56 -- reason being you dont risk that pivot snapping off-- which I have seen on an Early Bronco that only saw off-road trails not any long distance on rough roads at speed. I use oil impregnated bushings from mcmaster-carr to keep everything free. Protofab also sells the absolute very best bomb-proof cam latch on the market as well.
- Cactus Cooler
Re: Dual Spares
So I found this pic on the Web and was thinking of building this into my rear bumper set up. Really liked the set up on the DODGE ....What do you guys think?
- c6b646a96bb7b75a6c8ded0bb9f019c8.jpg (18.77 KiB) Viewed 1385 times
