Procomp COils
Procomp COils
Hello All,
Are the Procomp coils decent quality? There are a 2.5" set here locally that I am thinking about buying. More importantly if you do a set of C&T beams-- stock width-- you would add a couple degrees of camber right? How many degrees do the upper BJ sleeves account for?
Thanks,
Matt
Dezertbronco
Bronco Info: 1990 Bronco EB
Re: Procomp COils
Post by Dezertbronco »
Yes pro comp coils are fine, if you are going to cut and turn then I would use a 4" spring so you will get some useable travel out of it.
TurboJoe
Bronco Info: 1968 with 302 Highpinion 44 and 31 spline 9" on 38's and 1996 xlt 351 prerunner in the making
Re: Procomp COils
Post by TurboJoe »
I have 4" Procomps on my 96. Ride is great and the spring rate works well on big hits. They settled about an inch but I am still nose high. Giant Motorsports recommended using them as well.
joe
Re: Procomp COils
Joe-- hey thanks for the review-- thats kind of exactly what I was hoping/wanting to know. The Giant info is good to know as well!
Thanks again!
