Bronco in 1450?
CB95XLT
Bronco Info: 95 xlt all stock (for now) rolls on 33in general red labels
Bronco in 1450?
Post by CB95XLT »
I was just wondering if anyone one here knows if a bronco can run 1450 or are they limited to class3? I'm looking to take my project to the next level and make it race ready if I decide I want to.
Re: Bronco in 1450?
You could run it in 1450 class. If you build it to class 3 you will need to keep the rear leafs. 1450 would let you run links.
Re: Bronco in 1450?
I think the issue is wheel base. Youd have to stretch it to hit the sweet spot.
CB95XLT
Re: Bronco in 1450?
Post by CB95XLT »
Ugh....I definitely don't want to stretch it...but I'll have to read the M.O.R.E/Snore/HDRA rules and see what they say....if that plan doesn't work out I have my eye on single cab f-150
Re: Bronco in 1450?
I was thinking wheel base you know? Its short so whoops may slow you down.
Re: Bronco in 1450?
You can run any truck in 1450 as long as it has a stock cab and some stock frame rail, as long as it meets the safety/cage requirements.
A Bronco in 1450 would be extremely out classed though. 1450 trucks are just insane now. 500HP, 4.0 shocks, etc.
If you are keeping leafs, another class to consider is class 2000.
Re: Bronco in 1450?
I thought 2000 was limited to v6 or is that just mini trucks?
Re: Bronco in 1450?
We are thinking of running our class 7s in 2000 cause it's cheaper.
CB95XLT
Re: Bronco in 1450?
Post by CB95XLT »
Well the plan would be linking it...a built to race specs...I picked up a new dd so I was planning on building it to if I wanted I could enter in a few races...
Re: Bronco in 1450?
cs_drums wrote:I thought 2000 was limited to v6 or is that just mini trucks?
Nope, full size trucks can run in the class with V8's
