Rear shock shaft protection
Hey guys,
Just curious, what if anyting do you all do to protect the rear shock shafts from picking up all the rocks and crap from the front tires?
Anyone here using "dirt bags", some sort of shock boot, or those gnarly TT Mud Flaps?
gunit
Re: Rear shock shaft protection
Post by gunit »
tcm glx wrote:Hey guys,
When I raced stock full and had to stay under the bed with the shocks, I used sections of old 3" heavy canvas fire hose clamped around the body and open on the bottom, it worked great.
KBL
Bronco Info: Working on a '73 F-100 with a TTB conversion
Post by KBL »
I run these boots I picked up at McKenzie's.
This is a 2004 4Runner 4WD...and actually a pretty good application for the shock boots because the front wheels throw all kinds of roost at the rear shock shafts. I pitted my first set of shafts in fine style, which toasted the seals.
Copy of Cockpit safety 368a.jpg (141.73 KiB) Viewed 1605 times
www.off-roadweb.com
Polarcub
Post by Polarcub »
I dont run anything on mine as of now, I am considering adding dirt bagz front and rear. I like Dave's suggestion as a low cost alternative. With that being said, I have not experienced any damage on the shafts when my shocks were located under the bed, but I think that its a good idea.
Jeremy
Someone recently posted where you can get boots for 2.5" shocks. I think it was a thread here but don't remember which.
SteveG wrote:Someone recently posted where you can get boots for 2.5" shocks. I think it was a thread here but don't remember which.
Baja f250 shed the light. In his build thread he has a link to this place which sells 2.5" boots:
www.mirageraceproducts.com
Post by shockseals.com »
Fabtech part number:
FTS7000BK
Good for up to 12" stroke.
flyinbronco
HuckMASTER
Post by flyinbronco »
http://www.mirageraceproducts.com
Bill Varnes at Mirage is a terrific guy, a real class act for sure. Good place to spend your money. Ha Ha.
shockseals.com wrote:Fabtech part number:
FTS7000BK
Does that work on a 2.5" shock? If so, those are dirt cheap!
300
Post by 300 »
I will second that. Bill has been around forever, I attended a seminar that he did for VORRA nearly 20 years ago on setting up cars that has stuck with me ever since.
FTS7000BK
Thats what I use...
Steve, memory is the second thing to go!
Has anyone done trophy truck style mud flaps.... was looking underneath the Bronco this weekend, and thought that might be a quick and easy hit. I am thinking of using some leftover rear inner fender skins from the Bronco, mount them up to the rear shock hoop, so they sit right in front of the rear shocks..........
you aren't using ALL of my inner fender skins are you Tony? Rubber sheet might work better for this particular application.
ChaseTruck754 wrote:you aren't using ALL of my inner fender skins are you Tony? Rubber sheet might work better for this particular application.
Not all, but MOST..... I should have a few leftover, :)
tcm glx wrote:Has anyone done trophy truck style mud flaps.... was looking underneath the Bronco this weekend, and thought that might be a quick and easy hit. I am thinking of using some leftover rear inner fender skins from the Bronco, mount them up to the rear shock hoop, so they sit right in front of the rear shocks..........
That's how I plan to do it.
