Anyone have any good or bad news on Mr. Gasket Eng Set
ckymacias
Bronco Info: 1987 Bronco 302 4x4 with a updated front clip to a 93-97 grill
Post by ckymacias »
I'm going to pull my motor and do a rebuild. I already have the good Felpro oil pan seal, but I need the other gaskets to complete the rebuild and I found a killar deal on Amazon :)
Thanks B
PS I will have all my KOH pictures uploaded soon, just not sure which forum I should post them in? Any ideas?
damon1272
Re: Anyone have any good or bad news on Mr. Gasket Eng Set
Post by damon1272 »
Do yourself a favor and buy a gasket set from Ford rather than any other maker. Granted felpro makes most of the gaskets but they are made to a higher standard. Don't know what year truck you have but i would look for a 96 gasket set so that you get the new style pan and vavle cover gaskets. you will pay quite a bit but the quality is much better.
If I was going to re-seal or rebuild an engine I would use Fel-Pro. I prefer OE parts in a lot of areas, but for gaskets in a Bronco, I would not hesitate to use aftermarket.
I also see no reason to buy a gasket set from Mr. Gasket.
ckymacias
Post by ckymacias »
Thanks for the info guys!
300
Post by 300 »
I just pulled the heads off the old engine that we won 30 some races with, and realized they were Mr Gasket head gaskets. It is hard to go wrong with Fel Pro though.
I probably should have noted that unless your specific build requires out of the ordinary gaskets, I would use a standard Fel-Pro set. It's what's on my truck and they are working fine.
Victor is good, too but Fel-Pro seems better in many cases.
kylesgorter
Post by kylesgorter »
Fel-pro for everything but exhaust. i only use remflex gaskets for exhaust, i hate exhaust leaks and hate working on exhaust systems
