Shock down travel
- Jasonj105
- Bronco Info: 1989 Bronco, 5.8, C6
Shock down travel
How much shock down travel, not wheel travel are you guys running. Im working on my shock hoops and Im curious about what everyone else is running. Thank you.
Re: Shock down travel
Front or rear? I just set mine up so the shock was fully compressed when the suspension was completely compressed without a bump stop. The shock still has a little down travel due to the front coils and rear shackles restricting droop. I can measure at ride height if you would like. My truck is configured with a 12" SAW in the rear with an Autofab style mount and a 10" SAW in the front with a Camburg coil bucket.
- Jasonj105
Thanks Philo, I should have mentioned that it is for the front. Thats what I did, I ran my ttb up to the frame, and left about an 1/8 inch on the shock. Im using a 12'' 2.0 Fox, but it left me with about 4.5 inches of down travel on the shock. im hoping that translates to about 7 inches of wheel down travel. Does that sound about right? I've never built my own like this so I'm learning as I go.
If I'm reading between the lines correctly here, your asking how much droop travel you should have at static ride-height. Right?
Generally Broncos are set up with roughly 2/3 of wheel travel in bump and 1/3 droop.
- Jasonj105
Correct, At static ride height my shock is at 26.75 inches. At full droop it is at 31.25, which doesnt seem like enough, but thats at the shock not at the wheel. At the end of the wheel it looks like almost double the movement.
Do you need to know how to measure wheel travel?
- Jasonj105
No, I just wanted to know how much shock down travel from static ride height most guys are running.
