I'm sure Lee or Howe would rebuild your pump for a lot less than $350. For reference, they (Lee) rebuilt the current Explorer pump (stock specs) on my truck for about $100 and a few years ago they built a modified one for about the same price or a little more.yikes wrote:Talked with Larry at AGR about the 867257T pump. The price is $349 and he claims the upgraded shaft costs him $128. That sounds like a realistic price for a short run of a centerless ground, heat treated, high precision shaft. It flows 6gpm, which is almost 3 times the stock pump. He stated the pump can take continuous high/low rpm transitions in high stress rock crawler type applications for years without failing. He also said the plate cooler I'm running is great and that's what he sells for their systems. That being said...
Would Tommy Lee or Howe offer a Sag pump and/or rebuild mine for the same or less? Need to look into that.
Who makes a cost conscious remote can and reservoir set-up?
Personally I see very little reason to consider anything else other than a canned ham pump on a van bracket from a cost or performance standpoint. If you want to get a little sporty, get the same pump and figure out a remote reservoir setup.
Todd Z.
