fuel injected intake manifolds for 351w
Seabass
Bronco Info: 96 bronco
Re: fuel injected intake manifolds for 351w
Post by Seabass »
I wish man. I live in a condo. If I had a garage to tinker with maybe but not in the cards for now.
biggiek
Bronco Info: 92 Ford Bronco
Post by biggiek »
Does anyone of a diagram of the sensor location for the edelbrock lower? I want to essentially prep it so it's ready to be installed vs installing when I place in bronco.
Whiterhino1
Bronco Info: 1994 bronco 4 inch lift 35's
Post by Whiterhino1 »
Greg at total performance will port your factory manifold for around 200 bucks. If you know anything about his engines, you know he knows how to make power. He did this for a 408 we put in a bronco.
Lincoln came with the intake on the driver side.
Can the efi multi port typical spider 4 barrel intake be used and still pass smog? Lots of build have that kind of intake.
Whiterhino1
Try Greg at total performance, he did one for a 408 in a bronco for me. He ports the factory one, if you know Greg and his motors, you know he makes a ton of power and know his shit
Whiterhino1 wrote:Greg at total performance will port your factory manifold for around 200 bucks. If you know anything about his engines, you know he knows how to make power. He did this for a 408 we put in a bronco.
this is a great option as the eddy truck intake has gone up in price....
What about Extrude Honing??
S00TLYFE
Bronco Info: IT RAPTOR NOW
Post by S00TLYFE »
subbed and followed because I am currently in the same boat. Right now just trying to get the truck back running but going to stack parts and hopefully do cam heads intake hopefully next summer. changing an oil pump turned into a maf swap, Bassani y pipe and full exhaust, ac delete, and a ton of other stuff that pillaged my bank account for the time being.
VintageIronFab wrote:What about Extrude Honing??
Old school!
It's old but it should work really well on manifolds you just couldn't possibly smooth out the runners any other way though.
birdco85
Bronco Info: 95 5.8 MAF E4OD
Post by birdco85 »
Whiterhino1 wrote:Try Greg at total performance, he did one for a 408 in a bronco for me. He ports the factory one, if you know Greg and his motors, you know he makes a ton of power and know his shit
Are we talking Total Performance in Santee?
Whiterhino1
yes sir
http://www.gofastbroncos.com/forum/view ... &start=220
we need to remember the power Jim got out of the stock set up....
with a lot of us changing the intake and getting similar numbers.
