Seabass wrote:Is that the same saginaw pump casting that would come on athe e-series and the adapter is only so you don't have to buy a new bracket?
Yes, from what the tech guy said, these additional adapters (attached to the front of the Saginaw pump) permit a direct bolt on to the late model P/S bracket...giving you, the owner, one of their Saginaw Super Pumps with the correct shaft length and a turned down shaft to accept the OEM Ford pulley. That, and the required cutting and grinding to the OEM bracket to the accept the Saginaw pump (per above pictures.) OR...get that bracket and Saginaw pump from a donor E-Series van and go that route...?Seabass wrote:Denhabr did you get any prices with your email? Cost is pretty much the deciding factor for all my projects.
I just Googled the part numbers, and came up with these pricing figures:
- AGR #809156 (the worked-over Ford CII pump): $136 @ Summit w/ Free Shipping
- AGR #867257 (the Saginaw Super Pump w/ spacer): $242 @ Jegs
- AGR 'T' Option: Call them for contents and pricing
