Excuse my ignorance, what is Ackerman?ntsqd wrote:Doing so will slow down the steering. Can speed it up at the pitman arm, but then the added leverage goes away.
The real issue for me would be what it does for the Ackerman? OEM is not terribly great and I'm guessing that Ackerman isn't important to those who make those parts, so it probably suffers even more.
I do have a Howe steering Quickener I was thinking of using on the Bronco. It might make it better. I also am doing a swingset steering setup and I am double sheering the pitman arm to run a heim joint. I have a stock pitman and a 4in drop one in my parts box, so I will see which one works best for the cut and turn front end that will be set at 4 inches of lift over stock with coilover's.
David
