MAF Conversion ????
S00TLYFE
Bronco Info: IT RAPTOR NOW
Re: MAF Conversion ????
Post by S00TLYFE »
biggiek wrote:Not to butt it but I am thinking about doing this swap with an E4OD. I've read so many things in regards to computer to use and how a solenoid in the transmission moved from the transmission to the pcm etc. Mine is a 92 351w. Don't mean to steal from vintage just thought I would ask here.
Call and talk to Brian over at fiveology he will get you dialed. Super chill dude.
VintageIronFab wrote:Ok well I'm not sure at this moment whether the MOB1 computer works with the E4OD or not. So there's a couple places that sell these MAF conversion kits -there's http://www.mass-air.com/Products.htm
And Five o logy-- there's a huge difference in the kits cost. IST has been around for at least 20 years but at about $1500 it's not cheap. Most importantly is the power but that the E4OD works well together. Anyone use these people?
MOB1 is a E4OD MAF ECM
Is the MOB1 ECU same better or worse then the others??
MOB1 I would not say better just different. one stock ECU or PCM to run 351w and E40D
vs
The mustang style only runs Motor. my Black 1992 Bronco had Mustang ECM and USSHIFT tranny controller for example to run the E40D.
Five o logy sells both options I believe as well
cali kid
Bronco Info: '96 5.0 5 speed with stuff and things from Desolate
Post by cali kid »
The big issue like mentioned before is the lobe separation on the E303 the computer can't read it. With that set up any ecu would have to be tuned to get it to run right. My '96 Bronco is bone stock but in my Desert Dynamics sand car I'm running a 347 Stroker with all factory Ford electronics 89-93 Mustang A9L ecu. I'm sure you can run the same set up and get a stand alone for the trans.
cali kid
Post by cali kid »
Here's a pic of my motor.
S00TLYFE
Post by S00TLYFE »
that's a good looking set up you got there
S00TLYFE
Post by S00TLYFE »
funinthesun95 wrote:MOB1 I would not say better just different. one stock ECU or PCM to run 351w and E40D
vs
another option is to go C6 on the trans and then you don't have to worry about running a trans controller, or in my case, have a factory c6 with SD and go MAF
I absolutely want the OD
Anyone have a great resource for just a basic pinouts on these 3 vehicles?
-95 F150 5.8 4x4 E4OD
-95 F150 5.0 2wd 4R70W w/ MAF
-95 F150 5.0 4wd E4OD w/ MAF
