Bolt-on locking hubs for custom Bronco hubs .... need help
arse_sidewards
Re: Bolt-on locking hubs for custom Bronco hubs .... need help
Why not just fabricate a set of beams to use some late-model 1-ton knuckles and outers (Super-60)? You'd be miles ahead in terms of time and money at the expense of weight.
Scott likes excuses to keep his Bronco from ever being finished...arse_sidewards wrote:Why not just fabricate a set of beams to use some late-model 1-ton knuckles and outers (Super-60)? You'd be miles ahead in terms of time and money at the expense of weight.
Just kidding.
Pretty sure based on what parts he is looking into that he plans on fabricating a knuckle and is trying to eliminate heavy, weak, cast components.
- motoxscott
- Bronco Info: 408 Prerunner
I want something that anyone can buy that already has a Dana 44 TTB front end. If I make it too specific for a particular TTB, wheel bolt pattern etc, it limits it too much to only one type of customer/truck. Im not looking to make something cheap either. Sure cost is always factor but to a certain degree I dont want it to limit the direction I'm going. I don't want anything cast or super one-off. I want to use as many high-end parts that are already readily available and work well together.arse_sidewards wrote:Why not just fabricate a set of beams to use some late-model 1-ton knuckles and outers (Super-60)? You'd be miles ahead in terms of time and money at the expense of weight.
The knuckles, hubs and brakes are the last big ticket item I need to change on my Bronco. Philo is right ... I need something to further delay my project haha He's similar, hence why he just cut the back of his frame off.
Should have some solidworks renderings soon .....
- Scott
I only cut my frame off because Travis needed more frame for his Bronco. It's a vicious circle.
