Uniball Beam Pivots
Re: Uniball Part Numbers??
Thanks Philo!
Will These Uniballs Work?
Hello All,
I am wondering if these uniballs are what I am looking for?
http://www.ballisticfabrication.com/Uni ... _1613.html
then use these:
http://www.ballisticfabrication.com/Red ... _1716.html
-- On the beam pivots do you all like using 5/8" or 3/4" bolts??
Looks like I can get all the pieces I need for about $135 delivered
The only question I at this point I dont think I understand is the turning down of the parts.. do you turn down the cups or do you turn down the uniball itself?
Thanks for the help-- starting to get some parts to start the work!
Matt
then use these:
Matt
Re: Will These Uniballs Work?
You'd turn down the cups.
1.400 oal is the cup width as I recall after machining.
How Do These Uniball Cut-outs Turn Out??
How did these uniball cutouts turnout? I am going to wrap the ends after I get the cups installed-- figured 3/16" would be about perfect.
Thanks,
Matt
Thanks,
Matt
- photo 3 (11).JPG (112.68 KiB) Viewed 5664 times
- photo 4 (11).JPG (119.79 KiB) Viewed 5664 times
Re: How Do These Uniball Cut-outs Turn Out??
Run it! Mine arent even wrapped
Funny -- I was curious if anyone had been able to look at this-- Im about to head over to a guy a mile or so from here with a lathe to have them turned down to 1.40" -- I am wanting to bump the front end forward as far as I can.
Uniball Depth
Just wondering before I weld it up if this uniball depth --I am wanting to push the front end forward just about an inch fyi-- I had them turned down to a 1.4" width also.
Thanks!
Thanks!
- photo (13).JPG (106.1 KiB) Viewed 5647 times
- baja-chris
Re: Uniball Depth
Does that fit inside the pivot bracket? As the suspension cycles, the beam rotates...
Re: Uniball Depth
Yes it does-- what do you think of this clearance? I havent cycled it. If I am wanting the front end forward-- the pivot would have to be more to rear correct-- because as the beam cycles it will rotate forward and down. Sorry just trying to keep up a very quick pace as I have 9 days and 58 minutes to go
1st pic is max angle in the stock bracket
2nd is just showing you the difference in total width comparing the two pieces.
- photo 1 (14).JPG (133.32 KiB) Viewed 5621 times
- photo 3 (12).JPG (111.47 KiB) Viewed 5621 times
Re: Uniball Depth
Tack it, install beams, radius arms, knuckles and steering and cycle. Weld it up when everything is good.
Re: Uniball Depth
X2 on what Steve said.
Re: Uniball Depth
Like the guys said - tack & cycle is the only real way. It may not sound fun in the beginning & it may take longer, but it's certainly better on time than thinking it'll work & being just off & having to take it apart & fit it/do it over
Re: Uniball Depth
oh and most suspension stuff works this way unfortunately. I can't count how many times I've cycled stuff over the years. Seems like you just do it over & over again
Re: Uniball Depth
This. You get tired of putting it together and taking it apart again, but by the end you will be really fast at tearing down and putting it together. I can get mine assembled by myself in about 20 min minus brakes.ChaseTruck754 wrote:oh and most suspension stuff works this way unfortunately. I can't count how many times I've cycled stuff over the years. Seems like you just do it over & over again
Re: Uniball Depth
I agree with exactly what the others have said. There is no blue print for custom work. Each has there own dimensional quirks ect. Stuff gets bent and you can't tell till its measured up properly. It's not gofast or gofun but definately necissary, at bare minimum for peace of mind.
Re: Uniball Depth
Proper cycling is one of the reasons good fab work is very expensive... fit, tack, assemble, cycle, adjust, repeat, repeat, repeat. It's also the reason good kits are so expensive. All the hard work is done... bolt it all on and go play.
You've got a ton of work into your rig, take the time to cycle it and do it right the first time!
Re: Uniball Depth
Cycling trucks with 20" of wheel travel is just so much fun!
- funinthesun95
looks good
uniball are pretty forgiving ... Should be able to go 1 1/2 plus forward easy
well I just basically guessed on the uniball placement and you are right they will swing forward much further than really possible to use. I think I put the cup at 1/8" in front of the beam face for the driver and passenger side. Its my thoughts that if you are pushing the beam forward the centerline of the beam needs to be more to the back of the pivot mounts so they clear everything. Again the uniballs are really forgiving and I think it really doesnt matter much in the end-- but hey I am a total TTB newbie-- but an expert in training
