Has anyone run Raptor FOX's on their BRONCO?
Re: Has anyone run Raptor FOX's on their BRONCO?
shockseals.com wrote:
SteveG wrote:Do these only bypass on compression? Does rebound flow strictly through the piston?
Top out and last bit of travel are piston only in both directions.
Are they a "can in a can" type bypass? I could never get that setup to work well on my Bronco. At least not while retaining an acceptable ride on-road.
Mojo
Post by Mojo »
[/quote]
Are they a "can in a can" type bypass? I could never get that setup to work well on my Bronco. At least not while retaining an acceptable ride on-road.[/quote]
Yes they are Steve. So far they are working well for me, but I've only had it out one weekend to Ocotillo after I took them apart, changed the reservoir caps to schrader valve & re-valved the rebound.
Mojo
Post by Mojo »
A little Raptor SVT shock update. After going from the original .008 rebound stack to .012 it was much improved but still felt loose back there. So I increased to .015 stack & it worked very well in Ocotillo & I am very pleased. FYI, the compression valving is still original.
I am thinking of doing this. Does anyone have pictures of them installed in their bronco or obs f150?
johncharlesb
Post by johncharlesb »
I just picked up a set of fronts to use in my a arm setup, and have to rebuild them as soon as the parts come in. The fronts are 7" travel with the reservoir underneath resulting in a 30" shock, instead of a typical 18" shock for a 6.65 travel Bilstein 7100 class 11 type. I was planning on using the same geometry in the Raptor with my A arms. The upper shock mount is a 12mm 175 stem, and will be threaded with a chromemoly rod end. The coilover on a Raptor is 811 lbs. Too much for my Mountaineer so I will run the torsions still, although, I may switch over to 2wd springs, which are 550 lbs, in the future. The top hat on the spring mount is standard late-model F150 three bolt strut style. Some looked to be filling/altering the bypass holes and butterfly stacks to change bypass rates, but I am really over my head there.
Here is a link to the rebuild process with good pics of internals:
http://www.fordraptorforum.com/f9/diy-s ... ild-43929/ I usually disable java before going on that site because of the miles and miles of ads that load, good God.
PDF text:
http://raddrives.com/builds/Raptor/shoc ... SHOCKS.pdf
Geoff, Giant Motorsports has done them on a few trucks
Deslboy
Post by Deslboy »
I was planning to run these on the rear of my bronco with the Deaver Q80 pack, but upgraded to the spring under 64" deavers so I went with a different shock. I have them for sale, DC shocks completely rebuilt them and upgraded the reservoir caps with schrader valves so you can fill with nitrogen.
