cutting and turning
Re: cutting and turning
ESHALLBETTER wrote:Image
We need a "LIKE" button
I was hoping admin would be kind enough to rename this post "bad ass" :idea: :D
I second that hahah
Jbfab
Post by Jbfab »
Heres my shity beam welds for comparison.
Jbfab
Post by Jbfab »
CPT. SPRINGINGTON
Bronco Info: 1990 F150, T18 4 speed. C&T, 4"
Post by CPT. SPRINGINGTON »
those are really nice welds if they're from an arc welder.
ofcourse I'm going to video tape it when I jump it. i'll start with a small jump, like a few curbs 8-)
here is my jig to make sure I get it straight ;)
i'll be plating/reinforcing it tomorrow
I do admire your attitude! It looks like your going to be running a lot of lift?
Who wants to place bets that his beams won't break? I've seen railroad spikes used to fix busted to sand rail frames hold together though hard weekends, even in the rough stuff. It doesn't have to be pretty to work, post the vid. :| extra plating over the unions isn't a bad idea btw. Remember to keep your welding rods dry. If the flux is crumbling off trash em and buy new rod.
They may not break but ill bet money the axles will bind.
True...I really wanna see vid of this how,badass would it be if dude clears parked car or something.
baja-chris
Post by baja-chris »
hobbyturnedobsession wrote:They may not break but ill bet money the axles will bind.
Ding ding ding.
Winner winner, chicken dinner.
ESHALLBETTER wrote:I do admire your attitude! It looks like your going to be running a lot of lift?
Agreed! He ain't gonna let a bunch of poopooing ruin his day.
Ding ding ding.
The 4wd is just to meet class restrictions.
I was serious about agreeing with Erik. Run that shit and have fun doing it. But, you MUST take video! I always say, if I'm gonna do something stupid, I might as well get it on video! No offense meant by this.
After the video debut here his survivors should really post it up on you tube, he could be the next Rebecca black. I believe they start sending you monthly checks after 300000 views. He might make enough $$ to buy new beams, you just never know. :D
Look at the diff,it looks like he clocked it...
And Hell,if it last a few jumps,its good to go. Like I said,GIT'ER DUN
CPT. SPRINGINGTON
finished welding, just need to install. couldn't find any center Dana 50 Ujoints at the jyard.
does anyone know the exact years the dana 50 TTB came on? F350s? I searched a lot of F-250s but they all had dana44hd
yes I clocked the differential.
I have no idea if I have the angle right, I'm hoping the 2 piece bushings will make up for the amount of error. but I have 4" rancho springs, and i'll swap to deavers in the future.
-JD5353-
Post by -JD5353- »
Those bushings are not gonna help you at all. They are stiffer and have less give/flex. You may want to try to find another set of beams and just move the ball joint, there's alot less to it.
