Having been a bit of a "brake nut" for the past 15-20 years, I've had experiences running both Lincoln Mark V, Cadillac Eldorado, and Explorer rear discs on my little EB. The Cadillacs (those used in the BCB kit) are the least desirable if you want a working parking brake that keeps on working without constant fiddling. There are some inherent problems with the design that keeps them from being optimum. The Lincolns are better but still not as good for parking brake use. The "dumb drums" as Paul refers to them, have worked well in my experience. I think one of the differences between Paul and I's experience is that the Explorer setup has a better dust shield to it than the Wilwood kit. The Wilwoods are more "open" and probably prone to getting small rocks in there. I do A LOT of desert travel and haven't had any rock problems in the drums.PaulW wrote:BC Broncos sells a nice caliper kit for a 9" It uses new Cadilac cailpers and has a parking brake built into the caliper so you wont need the dumb drum setup. Call Chuck and he will help you out. Highly recommended and is what I put on my 72EB. On my 96 I have Turaus SHO calipers with built in park provision. No dumb drum brake. Cost more because custom hanger brackets mus be fabed.
Lesson. Drums get filled with small stones in the desert. This makes them wear and make noise and caused drag. Darn, these lesons are pricey. The Willwoods are for circle track guys
I suggest you might want to be leary of rock crawler suppliers. Any of the desert fab guys will give you much better advice. Learn like me - the expensive way.
PW
The calipers Paul is using now and the ones Chris has on his Cobra are both models made for Ford by Varga. They are the ONLY hydro-mechanical calipers I'm aware of that have a good, long-term, functioning parking brake in them. They are also the only remaining hydro-mechanical rear discs used by any OEM. They have all switched to the disc/drum-in-the-hat design. The advantage to the Varga calipers is that you can do a full-floater and still have a good e-brake.
My wish is that someone would make a bracket kit for the Varga calipers for the standard big bearing and Torino housing ends that would use some vented rotors (address another short-coming of the Explorer setup). Check out vintagevenom.com for a nice setup for the early Mustangs but it's only for small bearing 9" rear ends - this is what I have in mind. Make it for either the 2 3/8" or 2.5" axle offsets and everyone's happy.
Todd Z.
