tcm glx wrote:Got it....
For a poly mount, my thought was
1) you could mount the outrigger solid to the frame, and then the a, b and c pillar come down on a bushing
2) mount the outrigger to the frame with bushings...
preferably #1
Same as my thoughts T. Problem is - thinking it can be done while sitting at work (or wherever = not in front of the vehicle) & then actually pulling it off are 2 separate deals. While I'm sure it can be done I'm guessing it's gonna be harder than I initially think.
My 1st choice would be your option #2 above. It MIGHT be slightly easier to pull off, but I'm not sure.
For option #1 above you'd have a hard time tucking the outrigger tube as far up in the body as I would like from what I can tell. Also the higher up you tuck the tube the harder it gets to unbolt the bushings. Sure it's not something you will do very often, but if I go bolt on I want to actually physically be able to unbolt the things.
My issue with #2 is I'd like a bit of downward angle in the tube connecting the outrigger to the frame. From what I can tell in pics, etc. it seems the outrigger would be level with the frame. Not horrible, but not my best choice for way of doing it.
Another thing I am trying to consider in all of this is access to the tops of the tubes to weld. I like to tuck my cages REALLY tight to the body & therefore getting to the tubes to weld 360* can be TOUGH. My thought was do an outrigger type setup, tack the cage & then lower it through the floor a bit so as to get to the top of the cage to weld. This is how they did it on the DR link I posted yesterday & what I was planning on doing. Once the top tubes in the cage are welded you raise the cage back up into the cab & then plate the cage to the body. I takes a LOT of planning to pull off without any hiccups and figuring out adding bushings is only making my planning harder. Oh well.
Of course your build and priorities will vary from mine, but these are the issues I see myself facing when I get to doing this stuff.
Polarcub wrote:philofab wrote:Be aware that high back suspension seats are so tall they will hit the roof before flipping forward enough to get in the back.
This is a great point, I have the front flip mount from beard and hate it. The seat height does not allow the seat to come far enough forward to make it user friendly and the latch mechnism rattles when the seat is empty. I access between the center console as well.
Yeah - I tried the whole flip forward thing in my Ranger years ago and got away from it. Even in a full size with a lowback seat this doesn't work very well. Access to my rear seat(s) in the supercab will be through the middle of the front 2 seats. I will just have to keep my center console a bit shortened to keep this doable.
