If You Want Better AC Do This....
If you want better a/c you better not forget to put new foam on the inside of your ducts. The factory put it on the actual vents and I believe that was a simple engineering error- there’s much more surface area on the actual ducting that’s bolted the firewall. I personally believe if you buy some foam and a sharp brand new razor knife like I did - you will magically have more air volume hitting you in the face! The volume is so great I wish I could come up with a way to mass market pre-cut high quality sold high density foam because for me the results were dramatic- living in Phoenix I think that’s saying something!
Re: If You Want Better AC Do This....
Any pics of how you cut and fitted the foam?
biggiek
Bronco Info: 92 Ford Bronco
Post by biggiek »
Agreed I am sick of sweating!
I just took some 1” pretty squishy foam and pressed the vent into it, marked it with a sharpie, and guessed at the outside dimensions. If there is someone on here that has a computer controlled to cut foam that would be awesome. I mean if you have no Freon this won’t work but I’m convinced I was blowing a huge amount of air behind the dash instead of at me! I would say whatever you do- apply it to the plastic ducts behind the dash and not the dash vents.
450xracer68
Bronco Info: 1994 Bronco 5.8
Post by 450xracer68 »
Have you done the heater core bypass mod yet? I'm in Imperial Valley and its been 115 consistently and my A/C would blow at 75° to 80° max outta the vents.
Added a YG-350 Heater Valve that bypasses the heater core then ran the Vacuum line off a "T" going to Blend air door actuator . As soon as I was done, My A/C out of the Vents was 55°-60°. Was pumped to have Cold A/C again.
LvSteve
Post by LvSteve »
Any photos of your mod ?
biggiek
Post by biggiek »
450xracer68 wrote:Have you done the heater core bypass mod yet? I'm in Imperial Valley and its been 115 consistently and my A/C would blow at 75° to 80° max outta the vents.
Can you snap a couple pics of the install etc?
As long as you don’t have a ball valve or something that sounds great!
450xracer68
No Ball Valve or Jerry Riggin. This is the Thread I followed. Cost less than 50 Bucks for everything and works like a charm. I know the write up Below it says to use a Jeep Valve but the Ford P/N is YG-350. Its 32 bucks at Ford. I heard of the Autozone ones leaking right off the batt and I don't have time to mess around with it in the heat if it breaks. haha
https://www.fullsizebronco.com/forum/23 ... ntrol.html
