Edelbrock intake users: How did you mount the coil and TAB
- 96UAV
- Bronco Info: 96 XLT --Under Construction--
Just curious to see how y'all have mounted the bracket holding the coil and TAB/TAD? The Edelbrock lower intake doesn't come with mounting provisions like the factory.
- De$ertBronco
Re: Edelbrock intake users: How did you mount the coil and TAB
Hit up Bray (DMbronco) to snap some photos of his... My tech installed it for him a while back, I'll see if he remembers.
- CrazyBRONCOguy
- Bronco Info: 1992 and a 1978
I made a plate from aluminum that uses a few of the plenum bolts to holt it to the intake. Though Mine only holds a FPR and coil.
'92 Eddie Bauer- C6 Swap, 9" Swap, Roller 357W, AFR 165's, MAF, SCT Tuned, 4.10's
'78 Custom- 4" Deaver Lift, Mild 460, 8 Point Cage, 4.10's
- 96UAV
ThanksDe$ertBronco wrote:Hit up Bray (DMbronco) to snap some photos of his... My tech installed it for him a while back, I'll see if he remembers.
