Fuel injectorz
biggiek
Bronco Info: 92 Ford Bronco
Fuel injectorz
Post by biggiek »
I am planning on upgrading to the edelbrock intake shortly and was thinking about fuel injectors. Im sure it wouldn't hurt to rebuild them but don't have the time to fiddle with that. Anyone have a reliable source for rebuilt injectors? I saw some on ebay for about 80 bucks which to me is worth it. Any info would be great motor is a 92 351w and simply has gt40 heads along with headers for mods so factory is great.
Brandon
Re: Fuel injectorz
If it ain't broke, don't fix it. A simple injector treatment should be plenty. However, if you're going to go throught the trouble you should upgrade to the EV6 injectors. They have 4 orifices, instead of just 1. When you search EBay, specify 97 Explorer with a 5.0. Drop in replacement and upgrade.
Re: Fuel injectorz
I agree unless you plan on a dyno tune don't change
convoy
Re: Fuel injectorz
Post by convoy »
I just used Accurate Injectors out of Lake Havasu. Great guy to deal with. My injectors still looked okay when I removed them, though for piece of mind I sent them to be cleaned. They came back looking new, with new seals and he adjustment back within spec. He charges $18 per injector, no matter type. Took 2 days.
biggiek
Re: Fuel injectorz
Post by biggiek »
Thanks everyone figured since I'm going this far it wouldn't hurt to do it. Are these the correct ones if going to EV6?
http://m.ebay.com/itm/Reman-Upgrade-4-H ... Ciid%253A1
biggiek
Re: Fuel injectorz
Post by biggiek »
I've seen them for a 80 a set. These are 19 lbs and hr too correct?
Re: Fuel injectorz
If they're factory, they are.
Re: Fuel injectorz
make sure the harness plug is correct.
Re: Fuel injectorz
funinthesun95 wrote:make sure the harness plug is correct.
Definitely, make sure about the connectors. They should be the same but doubke, triple, and quadruple checking will save you from
headaches.
biggiek
Re: Fuel injectorz
Post by biggiek »
Anyway to ask someone how to?
Fuel injectorz
I'm pretty sure the stock injectors are EV1 and the EV6 need a harness adapter like....
https://lmr.com/item/M14464U2J/Mustang- ... DQodWdwKVg
Fuel injectorz
My 36lb injectors I have yet to install but I know they need the adapter Harness and are ev6
Re: Fuel injectorz
I personally would just -depin the stock harness and put the new connector on the old harness. I doubt the old metal pins are different.
