cowl update
- poolman
- Bronco Info: 84 Bronco,Body off reconstruction. Auto Fab suspension,mix of 84-96 parts.
cowl update
Anybody update the wiper cowl when you changed to late model fiberglass? Links? Thanks for any help, Mark
Jbfab
- Bronco Info: 94 centurion bronco 5.8/zf many mods more all the time.
Re: cowl update
If your talking about the 92-96 front end swap then yes you must replace the cowl. The 92-96 cowl is smaller then the pre92 iirc.
Re: cowl update
You can trim the earlier stuff to work too.
Re: cowl update
If you get conversion fiberglass from John at AutoFab you don't need to change the pre 92 cowl.
