rear spring hanger
jjconn
Bronco Info: 1995 5.0, 6"JBG prerunner
rear spring hanger
Post by jjconn »
Tried the search option, its been down for a couple hours.
I hung my j40's and the spring mounts are on their last leg east coast rot.....any suggestions for new mounts?
FUFIMI
Re: rear spring hanger
Post by FUFIMI »
Kelfab sells drop hangers with longer shackles or you can get stock replacement probably at bronco graveyard.
I think I have a spare set of stock ones... PM if needed.
jjconn
Post by jjconn »
Sorry for the ignorance but what does a drop hanger do? I have the 5.5 lift kit from bronco graveyard. It came with 5.5 deaver coils and j40's. We don't have a lot of open space here in delaware but we can drive on the beach. I got the lift to give a soft ride for the kids.
MOSS2
Post by MOSS2 »
I think you can get stock hangers and stuff through Summit racing also and they offer good service.
Reason people use drop hangers is to use a longer shackle or change their spring angle/ ride height a little.
With a longer shackle the shackle travels a little less degrees of motion through the travel and may help bushings live.
Doesn't sound like you need them if you are happy with height and don't beat on it a lot. Autofab typically sticks with stock stuff there so I would in your situation.
jjconn
Post by jjconn »
Thanks for the help! I'll start a build thread soon. Can't wait to mount the bumper I got from nick.
also check the ford dealer for the rear hanger. I've heard the fronts aren't too bad, so maybe the rear will be the same.
I had 2-3 sets here for a while, but the last set left not too long ago to head back east to a guy in your same predicament.
-JD5353-
Post by -JD5353- »
Autozone has ones that are honestly nicer than the stock ones for real cheap.
*********Autozone has ones that are honestly nicer than the stock ones for real cheap.
REALLY????? what brand are they-- talk about a great pearl of info!!!
-JD5353-
Post by -JD5353- »
Dorman. They are a little thicker than stock. I got the front hangers for 40 bucks I believe.
