For an 89 Bronco. the supply line is 5/16 with a 5/16 connectors correct? But what about the return line, is that 5/16 or 3/8? What about the connector size on the sending unit?
Thank you.
Fuel line size
the_hammer
- Bronco Info: Bertha-89 302: hydroboost, saginaw steering, ptfe fuel lines, lots of little misc
Re: Fuel line size
Return size from the sending unit is 3/8, supply is 5/16
- Phoenix0783
Re: Fuel line size
You always want the return size to flow at least as much as supply or it'll raise your fuel pressure. Not sure on the sizes myself, but the return is at least the same size.
Re: Fuel line size
typically on a hot rod-- if you have a -6an supply you run the same as a return.
