Bilstein extended rod end??
I've got Bilstein c/o up front and have been looking to see if there is a rod end extension for them but can't find anythng online. I know they make one for the 9300 "BlackHawk" series but i didn't see one for the 9100. I just want a 1" extension, anyone seen them?
Re: Bilstein extended rod end??
I'm not positive on this, but I believe that the blackhawks rod ends are compatible with the 9100 coil overs which would give you the extra length.
Call Joel.
9300 ends are an upgrade for 9100 shocks. They also feature a larger com bearing. I don't know if you will need to get a new lower spring cup though.
