Okay so I tried to start my rig the other day and it wouldn't start. Determined I had no spark at the coil. Purchased a new coil and still have no spark.........confused.......please help because a man without his rig is horribly depressing and will soon affect my marriage if I don't kick some sand soon!!
Thanks brothers!
PaulSr
Central Coast
1989 5.0 No Spark at the coil
Re: 1989 5.0 No Spark at the coil
First things to check change out is the EEC relay, then try the TFI module, lastly check to see if the PIP sensor is working.
- Phoenix0783
Are there any codes? Does it start if you remove the SPOUT connector. Check the cap and rotor and see what that looks like as well.
Check for +12 power to the coil.
