throttle position sensor (TPS)
- Andy Jones
- Bronco Info: In the Works!
how do you know when this is starting too go out? what does it do exactly??
- magic carpet XLT
Re: throttle position sensor (TPS)
erratic idle, and inconsistent throttle response were what i experienced. you have to remove the throttle body to replace the TPS so when i did that i also cleaned up the Idle Air Control Valve, cleaned the throttle body and sea foamed the engine and it ran a lot better afterwards. my distributor cap and rotor were also corroded which was probably the main culprit for my inconsistent throttle. if you have a manual there is a proper procedure for clocking the TPS when you install it, if you don't do it right you will get a high idle when you put it back together.
i'm up to 12 mpg on the freeway...
- Andy Jones
High idle! as in when you start the engine the RPM's shoot up past 1000! i had took it all apart and cleaned as much as i could. pain in the ass getting that thing off! anyways i put it all back together the way it all came apart. i guess I'll see how it works when i go for a drive this weekend. I'm kinda on my last leg with this POS..
On a side note, anyone that works on their own Ford EFI system should buy whichever of the following books corresponds to your vehicle. They have tons of information and good wiring diagrams.
http://www.google.com/products/catalog? ... sa=title#p
http://www.amazon.com/Ford-Injection-El ... t_ep_dpi_2
- miesk5
- Bronco Info: 96 Bronco, E4OD, Man Xfer Case & Hubs
bro,
In case you need to test/R&R that TPS, I have a bunch of Links in my site @ http://www.broncolinks.com/index.php?index=137
See our Big Bronco Technical, Parts Sources & Technical Service Bulletins Links site @ broncolinks.com
THANKS to ALL WHO SERVE
Would I have on of these on my 1986 5.0 ho mustang motor? It would make sense because everytime I start it the thing flys up in rpm and idles all over the place..
- miesk5
Yo Tower!
Yep, you have one in that 5.0
EDIT;
Had to Submit fast because my Comcast folks just don't have a clue as to why it isn't good to run the lines through the pinies and along lakes here.
I think your stangs TPS is the adjustable type...
Installation and Adjustment Instructions for 1986-93 FORD 5.0L MUSTANG w/ IAC
http://www.holley.com/data/Products/Tec ... R10018.pdf
iggie all but the TPS info
you can see the adj info in a Chilton or Haynes manual' autozone (I know..see the info about da zone below my av<
by registering at http://www.autozone.com
and Click Repair Guides...
Look here too; http://allfordmustangs.com/forums/5-0l- ... motor.html
BOO KOO Stang info !!
http://www.veryuseful.com/mustang/tech/engine/
Also;
Throttle Position Sensor (TPS) Screws TSB 89-14-07 for 89 & prior Light Truck & Car Lines
Source: by Ford via Steve83
TSB 89-14-07 TPS Screws
http://www.supermotors.net/registry/media/747753
Publication Date: JULY 14, 1989
FORD: 1983-89 CROWN VICTORIA, MUSTANG, TEMPO, THUNDERBIRD
1984-89 ESCORT
1986-89 TAURUS
LINCOLN-MERCURY: 1983-89 CONTINENTAL, COUGAR, GRAND MARQUIS, MARK VII, TOPAZ, TOWN CAR
1984-87 LYNX
MERKUR: 1985-89 ALL MERKUR LINES
LIGHT TRUCK: 1983-89 ALL LIGHT TRUCK LINES
ISSUE: All Throttle Position Sensor (TPS) mounting screws have a "Pozidrive" head. The "Pozidrive" head looks a lot like a Phillips screw head. Use of a Phillips head screwdriver to remove a "Pozidrive" screw will normally result in a rounded or damaged screw head. Many technicians think it is an overtorqued or "frozen" screw. An adhesive was also used as a thread sealant starting with the 1988 model year. This adhesive requires still more effort to loosen and remove the screw.
ACTION: To prevent rounded or damaged screw heads when servicing the TPS mounting screws, technicians should always use a #2 "Pozidrive" screwdriver.
OTHER APPLICABLE ARTICLES: NONE
looks like this
Professional Products Throttle Position Sensor (86-93 5.0L)
This Professional Products Throttle Position Sensor is designed as a direct fit replacement on all 1986 to 1993 5.0L Mustangs.
http://www.americanmuscle.com/profess-tps-8693.html
Suggest you do a Diagnostic Trouble Code Test (DTC) first to rule it in or out /find other problems... post any code found here
How To Run a Self-Test
http://fordfuelinjection.com/?p=13 by Ryan M
Don’t worry if the Check Engine Light is not on, the computer will store lesser important codes without flashing lights in your face. First you need to find the self-test plugs to read codes from the EEC. There are 2 plugs to find. One is triangular and has 6 pins; it is called the Self-Test plug. The other is a smaller single pin plug; it is called the Self-Test Input (STI). These are what the plugs look like. The self-test plugs are located along the driver�s side fender by the firewall on 1986-95 Mustangs.
EDIT;
Also;
1984-89 ESCORT
1986-89 TAURUS
1984-87 LYNX
looks like this
holy crap thanks for all the info! For $30.00 I might as well just replace it!
Thanks
Thanks
