Cruise Control
Cruise Control
Can the cruise control be modified to work without that brake sensor? Pressure switch maybe? Limit switch on the brake pedal?
- Firetwig
- Bronco Info: 1978 Ford Bronco 1996 Ford Bronco
Re: Cruise Control
You mean where tapping the brake does not turn off cruise? Sound's like a safety hazard...
Re: Cruise Control
Where is the stock sensor? Generally, all the sensor has to do is open or close a circuit. You should be able to do that easily. Cruise control switches were mounted on the pedal for years.yikes wrote:Can the cruise control be modified to work without that brake sensor? Pressure switch maybe? Limit switch on the brake pedal?
