does anyone know who does good driveline and driveshaft extending?
also what else needs to be done for drivelines to get them to bolt up and work right besides the extending part? do i need to modify the cross brace so the front drive line drops out more? should i do double CV joint because of the high angles?
what i have is a 4 inch over front and the 64" kit in the rear if that helps
Driveshafts and Drivelines for long travel
bajacowboy
- Bronco Info: 89 Bronco 4inch over beams, currie rear axle 5 inch over, BFG projects.
Re: Driveshafts and Drivelines for long travel
i dunno if ur looking for somthing local but some of the best stuff ive seen comes from high angle drivline up here in nor cal. its about an hour from my house. ive seen thier stuff all over in rockcrawling comps and on trophy/desert trucks, and its TOUGH and well built. they have mild to wild, some is spendy though. its worth a look, highangledrivline.com
