Dome light
cwrisley
Dome light
Post by cwrisley »
Mine is weak, plastic is faded, and I wanna upgrade!
Was wondering if anyone has come across a cool dome light setup? It would be cool to wire one up in the back of the Bronco too.
@cwriz
Re: Dome light
From what I have seen the dome lights out of the late 90's to 2000's taurus and similar car type ones work well and are a simple swap.
Re: Dome light
Post by shockseals.com »
Get a light for an RV. Less than $20, standard 1156 bulb, bright as shit. Put toggles into the lens and wire into factory wiring so they are still activated by door/headlight switch and have an on-off.
I did two in front and have 1 going in the rear since the factory rear one sucks.
Re: Dome light
Mine came out of a 2000'ish superduty.
-shockseals.com
Re: Dome light
Most Ford dome lights use the same mounting pattern. My truck didn't come with a rear dome light so I added one. I used another light from the front of a Bronco.
vegasff13
Bronco Info: 94 XLT 5.8 4in Rancho with 33in BFGs
Re: Dome light
Post by vegasff13 »
If what Philo said is correct chect out Recon lighting. They have a very nice LED dome for superdutys that I am sure you could make work.
cwrisley
Re: Dome light
Post by cwrisley »
@cwriz
Re: Dome light
This is what I used in my Falcon. It's cheap and super bright. You can wire it right to the stock wires or possibly use one of the adapters it comes with (I wired mine in).
http://www.dealextreme.com/p/t10-ba9s-f ... bulb-18060
There are a bunch of different sizes. Search for "dome lamp". I plan to add another at the rear of the falcon and install them in my tent trailer in place of the incandescent bulbs. You could probably leave these on for a couple weeks without drain the battery.
Re: Dome light
Any body have the recon? How does the brightness compare with stock?
