Body mounts.
Body mounts.
How do I remove the stock mounts from the frame without lighting them on fire?
Are they 2 piece?
Are mine just rusted together?
Am I stupid?
Should I buy a Cheby?
damon1272
Re: Body mounts.
Post by damon1272 »
Well stupid (you asked :mrgreen: ), you need to pull up the carpet and access the bolts from there. You may want to spray the bolts with WD 40 or something of that nature. You will need to jack up the body slightly to get the top part of the mount out.
Re: Body mounts.
Not that stupid...... Have bolts out, body is up, need to get rubber part out of frame. There is a washer on the top that has a sleeve that looks like it goes all the way through the mount with the washer/nut attached to the other side. Does this come apart?
Re: Body mounts.
BDKW1 wrote:Not that stupid...... Have bolts out, body is up, need to get rubber part out of frame. There is a washer on the top that has a sleeve that looks like it goes all the way through the mount with the washer/nut attached to the other side. Does this come apart?
Its a set of two sleeves that are usually fused together. Chris and I just spoke about this the other day, he even took some pictures.
You need to drill it out, I believe a uni bit is the tool of choice.
Conejoracer
Bronco Info: 1992 XLT 5.8, Beater
Re: Body mounts.
Post by Conejoracer »
Mine were fused, and it was a chore to separate them. I used an air chisel to slowly work around the inner part of the sleeve. The material is thin, so it took some time to do it without destroying them. In the end, the four cab mounts I replaced all came out okay and were reusable. The total time was less than three hours to get it done.
navynuke
Re: Body mounts.
Post by navynuke »
I replaced mine, using this method.
pull bolts out, insert long bolt from the top, and thread in a little, then proceed to beat the tar out of it with a sledge, and liberal use of PB Blaster
this half of the mount will pop out the bottom
picture of the inner sleeves with new bushings, bottom part is on the right
hope that helps some
Ken
Re: Body mounts.
All right, it is two pieces. Now that helps. OK, I'm off to do battle.
Re: Body mounts.
Remove the bolts from the top side.
Thread the bolts in from the bottom side.
Use an air chisel with a punch from the top side to drive the two halves apart.
Mine came out super easy. But, my truck and mounts had virtually no rust.
Re: Body mounts.
Aint nothin' can't be fixed with a BFH! :D :D
Re: Body mounts.
Uhhh, yes it is... Drill the worthless POS out!!!!!!!!!!!!!!
I HATE the fooking POS things! I may say it one more time just because I don't think I've gotten my true hatred for this crap design across yet :evil:
This body mount laughed at my 20 lb. sledge when I was beating the piss out of it with the method mentioned above. I ended up cutting the POS apart to get it out. My stainless drift is still wedged into the damed thing and will not come out. I'll be cutting the body mount thing apart even more later to cut it out.
Drilling them out makes short work of them...
Re: Body mounts.
Ken aka Navynuke,
Did your new sleeves slide in together easily? Because the set I received from LMC are super tight and won't go all the way in. Just curious, maybe they sent me the wrong set.
Re: Body mounts.
They are a press type fit Chris. They lock in totally once you tighten the bolt down in them.
Re: Body mounts.
ChaseTruck754 wrote:They are a press type fit Chris. They lock in totally once you tighten the bolt down in them.
Good to know because I have a new set for the silver Bronco and they look like they are going to fit tight into eachother.
navynuke
Re: Body mounts.
Post by navynuke »
I reused the old sleeves, mine actually pounded out quite well, gotta love AZ rust free trucks. All I replaced were the actual bushings themselves.
Ken
Re: Body mounts.
ChaseTruck754 wrote:My stainless drift is still wedged into the damed thing and will not come out.
The wedge probably spread the sleeve internally making it that much harder to remove.
I managed to work around them for the mean time. I now have a 32 gallon tank in the back of the F250, along with the rear cross member from the Bronco. I had always though Bronco frames were the same as F250 frame, just shorter. There are actually quite a few deferences....... Now if I could just get the sending unit to read right.......
Re: Body mounts.
Ford has stupid frame differences between the F-150, 205 and 350, let alone the 2wd to 4wd differences. Makes life really annoying at times.
And yes my drift seems to have spread the sleeve a bit. Again F this shit design!
poolman
Bronco Info: 84 Bronco,Body off reconstruction. Auto Fab suspension,mix of 84-96 parts.
Body mounts
Post by poolman »
Anybody had their entire body off? I wanted to know if anybody had a picture of the new mounts? I'm in the process of re-installing the body to the chassis but missing two of the upper pieces. I bought everything LMC had in stock. Any help or links appreciated,pm
050111 013 (800x600) (640x480).jpg (196.46 KiB) Viewed 2432 times
94 Bronco roller for parts
91 F150 4x4for parts
96 Bronco for parts
84 Bronco for 351W
sydude
Re: Body mounts
Post by sydude »
Yep. Take a look through my build thread.
Re: Body mounts
Just saw this in Barge's thread. Not sure if it helps or not.
Re: Body mounts.
Those body mounts were in primo shape, I figured it would be easier to buy new ones than get them out.........
