mastercraft baja rs recliner doesnt lock properly
- S00TLYFE
- Bronco Info: IT RAPTOR NOW
anyone ever had this issue? seats are less than a year old, i have reached out to mastercraft multiple times with out a response, so im hoping someone else ran into this issue and had a solution i could do on my own.
JebusTheGreat
- Bronco Info: I sold my 96 Ranger a few years ago and I am looking to build a Bronco now I am researching
Re: mastercraft baja rs recliner doesnt lock properly
Doesn't lock at all? or just moves around a little forward and backward once locked into position. Mine do the latter.
- S00TLYFE
The driver side literally will go flat if I lean against itJebusTheGreat wrote:Doesn't lock at all? or just moves around a little forward and backward once locked into position. Mine do the latter.
Stan the Man
Mine did that once or twice when it was new. About 3 years later and it never happened again. Maybe pull the side plates off and check that the pins are locking in place properly. Might just need to be aligned.
- S00TLYFE
thanks man, i pulled the plate off the other day but ran out of time, gonna have to see if i have some time to address it this weekendStan the Man wrote: ↑Tue Aug 04, 2020 11:20 pmMine did that once or twice when it was new. About 3 years later and it never happened again. Maybe pull the side plates off and check that the pins are locking in place properly. Might just need to be aligned.
