Ford says one should expect a stall multiplier of 2:1 from their various torque converters. (Others quote values like 1.8 or 1.9:1).
So the 2.71 becomes 5.42, but that is only at TC stall.
Anyway now you see why the manual trannys always have a lower 1st gear. Remember the granny gear trannys of old. This was done when autos were crappy and the trucks had to have a super low 1st to get going.
I don't believe the 2:1, but for sure the TC will give you a much lower starting ratio than the manual. To compensate we all just slip the clutch and specify a lower final drive ratio. Works fine for a while.
My story:
I have always had manual trannys until I deciced to have a offroad truck and then I chose the auto. The reason is when one needs to creep in low gear & shift fast, and it is just what the auto was made for. Sacrifice a small amount of MPG and enjoy the ease of driving. Point - have you ever had to downshift in a panic on a really steep trail or when you bog in unexpected deep silt? Good luck and even if you are succesful you will take some metal off the gears. With a auto it is seamless and can be done for an unlimited number of times. That is what we do on the trail and in the deep sand.
Bottom line an automatic best for desert use and I would still chooe auto for the trail. The trail guys always challange this statement and a lot of them are true believers in the stick shift. I challange their judgement.
Just my opinion based on my engineering evaluation. I will let the GFB guys challange my take.
Paul
mesquito_creek wrote:johncharlesb wrote:PaulW wrote: Sticks are going to need more gear too without the torque multiplication of the convertor.
Can you clarify this and explain "torgue multiplication"? So does a 5 spd m5od need a lower gear (488) or higher gear (456) versus and auto?
If I understand it correctly based on the gear ratio a manual should be turning higher rpms on 456 than a auto on 488s in 1st and overdrive....
M5OD-R2 3.91 2.24 1.49 1.00 0.80
E4OD 2.71 1.54 1.00 0.71
